Old 09-07-2002
dpoperngr is on a distinguished road
Gel coat vs epoxy for hull
Redoing a 30 year old fiberglass hull. Marina
has done questionable gel coat over bare stripped hull. I was told that gel coat will allow encroachment of moisture and that epoxy sealer should be done instead. Anybody know what I should be doing?
Old 09-08-2002
JeffH
Guest
Posts: n/a
I am assuming that you are discussing topsides. For topsides you have a choice of linear urethane paints (awlgrip) over epoxy or gelcoat over vinylester if you are trying to achieve a high degree of impermiability. For below the waterline you have the choice of vinylester or epoxy with epoxy making the more long term repair.
Old 09-09-2002
Hey Jeff, I''m doing hull below waterline. The Marina has already put gelcoat over bare hull. What should I do? Call it good? Can I go on top of the gel coat with epoxy?
Old 09-09-2002
JeffH
Guest
Posts: n/a
I am not sure what to tell you to do. If the marina was redoing your bottom because of blisters, chances are the new gelcoat will be even more pourous than the original gelcoat. If that is the case then I would think that the blisters would return in short order.
Probably if I were in your shoes I would apply something like Interlux''s barrier coat system.
Good luck,
Old 09-10-2002
Thanks Jeff. I really apprciate the help and advise. Smooth sailing!
Old 09-10-2002
windship has a little shameless behaviour in the past
This may be kinda late but mabey check-out the string from 18 and 19 Feb. 02 of ''gear and maintainence''
Dennis
Old 10-28-2002
Edboat is on a distinguished road
You might want to keep in mind that all epoxy barrier coats are not alike. You want to find one with the lowest moisture perm rate. We found a coating called Ceram-kote that is an epoxy with ceramics in it and it is tough as nails.
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
Epoxy on Carvel planking crkelly Gear & Maintenance 2 03-10-2001 08:39 AM
Epoxy Barrier coat stevemorrell General Discussion (sailing related) 3 11-07-2000 02:13 AM
