Old 12-09-2008
lofty22810 is on a distinguished road
paint strippers
whats the difference btween fiberglass paintstripper and household?? how does household hurt your boat? I applied this to my keel and nothing bad happened... most of the old bottom paint came off and which that is my goal? i dont have the maony to soda blast but i do have alot of time since being laid off..also how should i fair my keel what products are good? i have a lancer 36 with alifetime of bottom paint on her!!! I think its time..
Old 12-09-2008
Leither's Avatar
Retired and happy
Leither is on a distinguished road
Like lots of areas of boat maintenance, the issue of stripping off paint has its own complexities and strongly held views. If you search on SailNet ("paint strippers" and other combinations) there is a lot of information out there.
In brief summary, standard hardware store paint strippers contain methylene chloride, a strong solvent which can damage the gelcoat. Most marine-based strippers are designed not to damage the gelcoat.
You will also see other paint removal possibilities from a search, including soda blasting, for example.
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Old 12-10-2008
Sailormon6 will become famous soon enough
Household paint strippers are too aggressive, and will dissolve your gelcoat. Paint strippers that are designed specifically for fiberglass seem to work as well as other types, without harming the boat. If you used it on your keel without damage, it might be that your keel is lead or iron, and has no gelcoat on it. Klean Strip (kleanstrip dot com) manufactures a chemical paint stripper for fiberglass that I have used, and found it very satisfactory, and it's much less expensive than some marine strippers.
Stripping years of accumulated antifouling paint off the bottom is hard, unpleasant work, and the only easy way to do it is if you hire it done, but chemical strippers will get the job done, if you're patient and determined. It helped me stick with it to think about how fast the boat would be when the bottom was smooth and clean (and I wasn't disappointed).
Environment friendly paint strippers ccriders Gear & Maintenance 10 02-03-2008 09:10 PM
Paininting non-skid... marinesniper Gear & Maintenance 36 01-29-2008 01:10 AM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
