Old 12-10-2008
wchevron's Avatar
Detachable member
wchevron is on a distinguished road
Cleaning up battery acid
i spilt some battery acid on my basement floor. is there a way to neutralize it?
wchevron
s/v Time Flies
'78 C-30
Old 12-10-2008
badsanta is on a distinguished road
arm and hammer soda and water
Old 12-10-2008
JHJensen's Avatar
Marine: Educator,Surveyor
JHJensen is on a distinguished road
Send a message via Skype™ to JHJensen
Exclamation Battery Acid vs the Basement
Chevron
I don't know how big your spill is....
Yes you can clean the acid up using baking soda (Yes good ole Arm and Hammer) with water.
Put some baking soda on the spot. Don't be shy it is cheap. Then collect the results. Put down more soda and add a bit of water...not too much...just enough so you can move it around and clean with it.
Do not use a shop vac to clean up. Use plastic tools.. cut them out of old plastic like soda bottles or yogurt containers. Any rags you use throw out.
Wear gloves and eye protection if there is alot of acid.
You will know you have it clean when you put down a little baking soda mixed w/water ( a slurry) when it does not bubble at all you are done.
Put all the junk in a plastic bag and discard.
If you are wearing cotten clothes like jeans etc and you see holes after the next wash you will know where they came from... but better there than your eyes... also if you feel any burning sensation on your skin... lots of water and baking soda....
J.
"It's not just about the vessel... more importantly it is about the people, their safety and their vessels in that order. "(PFJ 1952-1986)
Old 12-10-2008
wchevron's Avatar
Detachable member
thanks for the help.
wchevron
s/v Time Flies
'78 C-30
Old 12-10-2008
MoonSailer is on a distinguished road
Lead!!!! Battery acid is full of lead which is highly toxic. Dispose of properly please!!!!
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 07:07 PM
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 08:00 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 08:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
