Marelon y-valve and sea**** stuck! - SailNet Community
post #1 of 12 Old 12-10-2008 Thread Starter
Help! I have a seacock handle in my hand !
Our 1984 Islander 28 has Marelon seacocks (i believe) that appear to be stuck. The original paperwork from her birth states that is what was standard and I could not find any receipts that prove otherwise. We had one y-valve handle break in our hand last weekend and it did not let any water in but is now in need of repair. The seacock handle is also stuck and will not move but before we break another handle (and this one to a valve accessing the ocean!) is there anything we can do to trouble shoot this?
Here are our seperate theories...
I think that the valve is in need of lubrication? Could that be the problem and if so then what would be an appropriate lubricant ? The owners manuel does not mention lubrication.
My hubby thinks that there could be some sealife stuck in the external side of the thru hull. We did have her bottom painted in about March of this year and her bottom cleaned about one week ago and they said they cleared any visable debris on around the thru hulls.
If anyone has had any experience with these type of ball valves and any advice they could offer please do . . . . .
Nic Ferrante
S/V Briny Marlin
Islander 28
Hull#391
nicferrante is offline
post #2 of 12 Old 12-10-2008
Nic-
Marelon ball valves and seacocks need to be exercised regularly, at least once a month, and lubed annually. If you don't do this, they will seize up and then when you try to turn the handle, the handle will break.
sailingdog is offline
post #3 of 12 Old 12-10-2008
old guy :)
rikhall's Avatar
In correspondence with Marelon (yes there were happy to talk with me) after breaking a handle off, they said to actually loosen the the seacock as if unscrewing it from its base. Took less than 1/8 of a turn and it moved quite freely. And, I think they even sent me a new complete seacock.
I agree that they like to be exercised, but they can certainly be too tight as well. I took the hose off and turned it just a bit and thing were fine.
Irwin Citation 34
Mystery
rikhall is offline
post #4 of 12 Old 12-11-2008 Thread Starter
Question
thanks ! I will try to loosen it...if I were to lubricate the seacock does anyone have any suggestions of products to try?
Nic Ferrante
S/V Briny Marlin
Islander 28
Hull#391
post #5 of 12 Old 12-11-2008
Lithium grease or LanoCote...
post #6 of 12 Old 12-12-2008
When was the last time the boat was hauled?? If you need bottom paint, I would haul it first and take care if it on dry land.
badsanta is offline
post #7 of 12 Old 12-13-2008 Thread Starter
we just hauled her out a few months ago
got her blisters taken care of, bottom painted and top sides polished. We were hoping not to have to haul her out until next spring again!
Nic Ferrante
S/V Briny Marlin
Islander 28
Hull#391
post #8 of 12 Old 12-13-2008
Lithium grease is a petroleum product, and Marelon is I believe a glass filled nylon. There also may be o-ring seals involved, possibly EPDM. So I think a safe bet all around would be a silicone grease, like a vacuum grease.
GaryHLucas is offline
post #9 of 12 Old 12-13-2008
Gary- Forespar recommends winch grease, lanocote or water pump grease. I'd imagine the winch grease is a petroleum product, so I doubt lithium grease is going to damage the seacock, if winch grease doesn't.
post #10 of 12 Old 12-13-2008
If the maufactuer recommends it, then I am okay with it. However I work in the waste water industry and we have ots of problems on seals of all kinds from the wrong lubes. In general the silicone is safe on damn near anything, except body parts. That's why I suggested it.
Stuck Valve after installing rebuilt A4 upnatit Atomic 4 20 03-30-2009 11:47 PM
Thru hull stuck Jotun Gear & Maintenance 25 03-11-2007 08:20 PM
