12-11-2008
I wouldn't have the Lavac pull water from the freshwater tanks. If there is any back flow, you could seriously risk the health of your family by contaminating the potable water system.
It would make much more sense to plumb it into the drain of the head sink, with a diverter valve that allows the head to either drain overboard or be used to flush the head. That would eliminate any risk of contamination whatsoever, and allow you to flush using grey water... which is a better use of fresh water resources on a small sailboat.
IMHO, you'd also be better off running the Lavac's discharge hose directly into the holding tank, and then putting the y-splitter in the pumpout hose of the holding tank and adding a diaphragm pump to the side of the "y" going to the seacock and through-hull.
This would give you a much more flexible waste handling system, since you could pump the holding tank overboard whenever you're out past the three-mile limit, and don't require a pumpout facility or boat. You really haven't lost any functionality, since anywhere you could have pumped the head directly overboard, you can empty the holding tank.
Using the vented loop may cause the Lavac to have some problems flushing properly.
