Old 12-12-2008
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Need some ideas for a swing keel cradle...
Yesterday, I removed the trailer out from under my South Coast 22 project sailboat with the help of a floor jack and a bunch of blocks. Now I need to remove the swing keel so that I can refinish it.
I was wondering if anyone had any ideas of how I should "catch" the keel when I drop it out of the boat. I want to build a cradle to hold the keel pretty much. I have access to plenty of 2x4's to use. I would like the cradle to be able to be moved pretty easily, I think. Maybe I could just drag it wherever it needs to go (not far, just around the house). The bottom of the hull is about 2.5 feet off the ground.
I have googled it and found a few things but nothing that really helped, so I figured I would pick everyone's brains and see if they had any excellent ideas.
Thanks Everyone,
Trip
Small is beautiful, simple, cheap, and easy......
Visit my website
! Lots of useful info and sailing videos.
Old 12-12-2008
Cope44's Avatar
Censored4 your protection
Cope44 is on a distinguished road
Can you weld? An easy way would be to weld a plate with uprights to a floor jack. Jack up jack, remove keel bolt, lower jack. I dont like the idea of a 500+ LB. plate falling any where.
Good luck and let us know how it turns out.
Cope
CM 21 #291
I fight to refuse a battle of wits against a one armed man.
Old 12-12-2008
geraldartman is on a distinguished road
In the catalina 22 stuff there I remember reading about a cradle for removing the swing for reburb and pivot repairs. I forget exactly where but do not think in was in the subscription stuff.
Old 12-12-2008
Perithead's Avatar
Montgomery 17
I cannot weld, but we do have a welder here at the house. It is a skill that I would like to learn, I will throw the idea at my step-dad and see what he thinks.
Ill check out the Cat 22 stuff.
I will definately let averyone know how it turns out, I am documenting the whole restoration of the boat and will be posting it online. I have one video on Youtube and on my website which is in my signature, go to sailing videos and its down the page a bit.
Visit my website
Old 12-12-2008
rayncyn51 is on a distinguished road
You might try using a stacked wooded crib and bottle jacks, like a house mover does. Mke a cradle with casters to hold the keel, crib it up under the keel, drop the keel into the cradle, then jack down the crib until the cradle casters hit the floor. Reverse the steps to put it back.
Are we there yet?
Old 12-13-2008
GaryHLucas is on a distinguished road
Thanks Everyone,
Trip
I built a simple U shaped bracket with a pin on the bottom that fit into to the hole that holds the saddle on a floor jack. Piece of cake to remove and reinstall the swing keel on my Catalina 22, by myself! I also used the floor jack to load it it in the back of my van (put jack near the middle and raise one end, back under it. lower onto a piece of pipe roller, jack up the other end and push it the rest of the way in.) Put in in the shed the same way. Flipped it many times in the shed while working on it. (Used a nylon strap over the jack wraped around the keel to flip it)
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Wing vs Fin Keel pixurman General Discussion (sailing related) 10 05-28-2004 04:01 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
