12-16-2008
Hi Rik,
I did talk to Raymarine and I can cut a new slot in the back of the wheel pilot to locate the motor lower. This slot sit on a pin that I fastened to the pedestal tube, it's sole function is to keep the back of the wheel pilot stationary.
My thoughts would be to look into the built in gyro option for the wheel pilot. If this means you don't need the rudder position transducer then it my be worth it. The transducer on my boat is tough because of limited space to work as is the case on most boats. Another age old question is where is the best location for the control head, if you have the perfect spot let me know where that is.
I planning on putting it at the pedestal guard in a nav pod with my wd&s as I am planning on getting a remote also.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
