12-14-2008
That kind of depends on how strong you are, now doesn't it??? I'd highly recommend going with at least 30', preferably 50-60' of chain. Anything more than that is overkill unless you anchor in areas with coral heads all the time.
One thing that will help a lot is a chain pawl. Makes it much simpler to haul the anchor up... since you can let go of the anchor chain to adjust your grip without the chain rattling back overboard. A good chain pawl helps a lot if you don't have a windlass.
One common type looks like this:
As for bow rollers, it really depends on how your foredeck is setup. A photo of it would help...as would saying what 31' sailboat you have.
The ground tackle setup I installed on my boat looks like this:
It is a bit tight, but that is mainly due to the fact that a trimaran has a pretty narrow foredeck.
Originally Posted by Danjcon
We have just completed our first season as owners of a 31 foot sailboat. This has been a dream come true, and I have been addicted to this site for a year and a half. So now I have loads of questions for all the experts.
I bought a 22 lb Delta anchor. I do not have a windlass. How much chain can I use (weight wise) and still be able to pull the anchor up manually? I have a winch on the main mast. Also, I am going to add a bow roller. I have looked everywhere, and looked at many boats, but can't tell if it is better to install the bow roller parallel to the deck, or at an angle to the deck. If parallel, would I use a block of wood to support the back end?
Dan
