12-14-2008
I'd second what Vasco said, but recommend going with 45-60' of snubber... since in many situations, when it starts to really blow, you'll want to let more scope out. If the snubber is too short, you won't be able to do that without hauling it in to unhook the snubber and then letting out the scope and then re-attaching the snubber. If you have a long snubber to begin with—you can just ease out both the chain and snubber to add scope. A 45' snubber would allow you to let you go from 5-to-1, up to 7-to-1 scope in 15' of water, assuming you had let out about 10' of snubber initially.
A longer snubber also allows you to adjust it more easily to spread chafe out along more of the snubber...
