Old 12-30-2008
sander06 is on a distinguished road
Thanks for the info. I drained/pumped the tranny oil out and found that it was a real mess. It looked like it was mineral oil or regular oil. Anyways, I've put in regular ATF, but it's still got the problem. The PO said that he had the tranny rebuilt just before I bought it so it must have new thrust bearings, etc. I'm thinking that the tranny may just be gunked up with crud from the original oil that was used. I've also considered just flushing the entire thing out to clean the works, but I'm not sure what to use as a flush although diesel fuel has been suggested. I may have to bite the bullet and consult with a tranny mechanic!
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
  #12
Old 12-31-2008
timebandit's Avatar
timebandit is on a distinguished road
Get some B&M slick shift automatic transmission fluid.
My local Auto Zone carries it.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
  #13
Old 12-31-2008
Don Radcliffe
donradclife is on a distinguished road
I had exactly the same problem with my Hurth, and had it rebuilt when I got to Australia. While they said they couldn't find anything really wrong, it worked fine for 10 years after they were done. There are a lot of instructions in the Hurth manual about shimming this and shimming that, and I decided it was best left to the pros.
You may post attachments
You may edit your posts
transmission question almostbroke Gear & Maintenance 10 09-17-2012 09:56 AM
2GM Transmission, going forward when engaging into reverse Stephane99 Gear & Maintenance 2 10-20-2008 10:19 AM
Transmission woes sailrmon Gear & Maintenance 2 10-15-2008 05:18 PM
Shorepower and Reverse Polarity oft Gear & Maintenance 20 12-03-2007 09:46 PM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 08:00 PM
SEO by vBSEO 3.6.1
