Dropping the Keel - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 02-04-2009
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
Maine Sail is my hero. You should write a book. Perhaps you have.
Back in the day, people were opposed to the idea that the world might not be flat.
  #12 (permalink)
Old 02-06-2009
matt2 is on a distinguished road
Spot On!
Thanks for your comments Tommays & Maine Sail.
It is pretty clear now. It looks like its 5200 then fair the join for cosmetic purposes.
The crack might reappear but no big deal, just refair when required (or not) since the 5200
is should ensure no water ever access the bolts.
Now there is only one thing (that I know) I am not sure about;
i.e. Whether the keel bolts should be fully tightened before the 5200 has set.
I am guessing that they should not be.
Anyway thanks again.
  #13 (permalink)
Old 02-06-2009
Maine Sail's Avatar
No they should be tightened once the boat is set down. Tightening partially cured or cured sealant leads to movement and seal failures. You want a sealant in there NOT a flexible gasket. This is why you cut a "gasket groove" that will retain a nice thick bead..
______
-Maine Sail / CS-36T
  #14 (permalink)
Old 02-06-2009
Excellent!
I now understand the purpose and importance of the "gasket groove".
Thanks, again!
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 07:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 05:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 10:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 08:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
