Old 12-18-2008
Solla Sollew
SollaSollewSails is on a distinguished road
Fiberglass Repair
I was hit on Block this summer. One yard was going to fill and apply gel coat for $450. Another told me the glass mat had been crushed slightly and wanted to do a full grind out job to the tune of $2400. Moreover, they indicated I should do the work ASAP lest any moisture work it's way in the the mat. Yet another yard indicated the job would cost somewhat less but that there was no particular rush to do it. It could wait, in other words, till the spring.
The boat is 3 years new and I will be paying for the work.
Opinions?
Eric
Old 12-18-2008
camaraderie's Avatar
moderate?
Difficult to say without pictures if just your gel coat was damaged or if damage extends into the laminate. You have to decide based on what they showed you.
Yard 3 should never have said NO RUSH. You are in freeze country and any water in those cracks can freeze and expand over the winter causing a bigger job in the spring.
If you can see the laminate...I think the guy quoting $2400 is probably right.
Old 12-18-2008
I'd second what Cam said. Unless you're storing the boat in heated storage, any damaged laminate needs to be covered so water doesn't get into it and freeze.
Old 12-18-2008
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
It would be cheaper to do it yourself, using my bible "Don Caseys complete sailaboat maintenance manual," if you are a little handy with tools and glass.
Saurav16
1979 Catalina 27 Tall Rig
Day sailor on the
Hudson River-NY
Old 12-18-2008
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
It's impossible to say without seeing - at least - some photos. If you did damage the laminate, the only way to fix it is to grind it out and re-lay some new glass (as Cam and SD have already said).
-Jason
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
Fiberglass repair question merttan Gear & Maintenance 7 06-17-2008 12:47 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
