What will freeze? - SailNet Community
post #1 of 7 Old 12-21-2008 Thread Starter
Learning & Loving It
berkshire1's Avatar
What will freeze?
I have a 28' that I keep in the water on a small inland lake in North Texas. The weather is usually fine. In fact I went out for a few hours yesterday afternoon. There is a cold front that has come thru (29 degrees) and I noticed a few people putting heaters inside their boats.
What can freeze? I do not have shore power or water. I have maybe 2 gallons in my water tank. Portable john is empty.
Is there anything I should be worried about other then the 3 "cold ones" I left in the galley?
berkshire1 is offline
post #2 of 7 Old 12-21-2008
Shaken-not Stirred
capngregg's Avatar
Cool
Which lake are you at? I live in Carrollton and use Lake Lewisville or Grapevine as my playgrounds.
If you have any type of traps (sink, waste, etc.) those may freeze. Any water lines that supply fresh water to the sink, etc. may freeze and the water in your fresh water tank may freeze depending on its location.
The "cold ones" will probably not freeze since it won't get cold enough for long enough to make them freeze. Best bet on those is to consume them immediately.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
capngregg is offline
post #3 of 7 Old 12-21-2008
Water in your engine cooling system
xort is offline
post #4 of 7 Old 12-21-2008 Thread Starter
berkshire1's Avatar
I'm on Lake Ray Hubbard at Chandler's Landing. Thanks for the comment. I don't think I have anything to worry about.
If the cold ones freeze and explode, then the boat will smell like beer and the wife won't come out anymore. Gee - why didn't I think of that sooner!
post #5 of 7 Old 12-21-2008 Thread Starter
berkshire1's Avatar
Xort - I have an outboard. But the 2 people I saw with heaters have inboard diesels.
post #6 of 7 Old 12-21-2008
how about the water in the impeller of your outboard? No water lines to a faucet inside the boat?
badsanta is offline
post #7 of 7 Old 12-21-2008
'87 Pearson 27'
jackytdunaway's Avatar
i live on Lake Norman in NC and we see mid 20s all the time (sometimes into the teens) and i rarely even turn on a heater in my boat. i leave water in the fresh water tank and the engine is not winterized. Sitting on the lake water helps protect it. As long as there is not a real sustained cold the little bit of heat from the unfrozen lake should keep you safe. I can't speak for the out board engine. i have an inboard diesel.
jackytdunaway is offline
Winter Sailing davidpm Gear & Maintenance 33 12-01-2009 09:59 AM
Cheese - Freeze it?? kezguy Provisioning 14 05-20-2008 08:14 PM
Unable to Circulate anti freeze into engine Please HELP! saurav16 Gear & Maintenance 8 10-14-2007 07:34 AM
Do I nee to winterize? mathislaw1 Gear & Maintenance 26 03-13-2007 09:28 AM
refrigeration hathanger Gear & Maintenance 19 04-08-2005 06:21 AM
