Old 12-21-2008
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
What is this thing on the head inlet hose?
Ok, so there's a white cylindrical thing on the inlet hose to each head. That's right, the one side goes to the seacock and then to the through-hull. The other side goes to the Jabco head.
It has a screw cap on the top, that opens to a small compartment that doesn't go anywhere. The may be for holding fragrence or something, since it doesn't seem to connect with the hoses going in or out.
What is it?!?
Old 12-21-2008
painkiller's Avatar
Apropos of Nothing
painkiller will become famous soon enough
What's the label say? I can't quite make it out.
Old 12-21-2008
Bene505's Avatar
Not sure what it says. I'll have to check later this week.
Old 12-21-2008
Saildoggie's Avatar
Salty Dog
Saildoggie is on a distinguished road
Maybe set up to put a stariner filter in there, funny, what makes lots of heads stink is the dying organisms you pumped into the bowl!!
An over 40 victim of fate
Old 12-21-2008
It's probably a dispenser of some sort for some head treatment chemical.
Old 12-21-2008
JohnRPollard's Avatar
Moderator
Bene,
We have the same unit on our head. It is an in-line treatment system, that helps to reduce odors in the toilet and holding tank. The top unscrews and then you drop a large, cylindrical tablet into the cartridge. Intake water passes through the cartridge on the way to the toilet bowl. The tablet turns the water bluish, just like those tablets you might use in your toilet at home.
The replacement tablets are sold at chandleries like WM, but I am blanking out on the product name. Something like "Waste Treatment Tablets". They are packaged in a small white nondescript box. They are a bit pricey, so I don't replace ours as often as I should.
Old 12-21-2008
camaraderie's Avatar
moderate?
I think it is a tankette deoderizer:
N.E. Marine : F.C.P. Products Solves boat head odors with head-o-matic tankette (tank-ette) also bilge oil cleanup with bilge blotters
Old 12-21-2008
Bene505's Avatar
You gentlemen make sense, and that looks like the thing. The only lingering doubt is that the chamber doesn't look like it connects with the intake water. That is, unless there's a small hole in there somewhere. (And I think that there was such a tablet on the boat.)
Old 12-21-2008
Moderator
Yeah, it looks kind of funny in there when you take the lid off. It appears like a sealed chamber, but somehow the water passes through it. I think the design limits the amount of pass through water that contacts the tablet, so that it doesn't dissolve too quickly.
Old 12-21-2008
Bene505's Avatar
10 points each for SD, John and Cam! Thanks gentlemen.
Bilge pump preference Shortman Gear & Maintenance 16 03-18-2010 12:49 PM
Anti-siphon in head supply hose? jrd22 Gear & Maintenance 16 10-17-2008 01:57 PM
Fort Pierce Inlet to Hilton Head Island PBzeer Cruising & Liveaboard Forum 11 06-01-2007 07:25 AM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
my boat stinks agent4change General Discussion (sailing related) 15 12-03-2003 11:25 AM
