12-24-2008
If you get it from an automotive glass shop, it usually has the higher melt point, since automotive interiors get far hotter than most boats do.
Originally Posted by bljones
One challenge with some types of butyl tape is that they have a relatively low melt point, as low as 105 degrees fahrenheit. Not a big deal on a light coloured hull in northern lats, but it could be a problem on a warmer teak deck. Check the spec sheets on the tape you are thinking of using, and look for a tape with a melt point above 200 F. It will also generally be a more durable tape, with a higher elasticity rate.
