What size CDI roller furler - Page 2 - SailNet Community
post #11 of 13 Old 12-26-2008
Retired and happy
Leither's Avatar
Originally Posted by dgr View Post
captainmidnight,
Like everyone else, I am looking for the best value when shopping for this. I don't have a specific price point yet as I am still looking around.
My stays are 6 months old. (There we go again, more money than the boat is worth ) I will make sure that the stay is toggled on both ends with whatever furler I install.
As a matter of interest, I paid a smidgeon under $600 for my FF6. I replaced the forestay, but only because it was very old and worn. You certainly won't want to replace a 6 month old stay if you can possibly avoid it, assuming that the toggle issue doesn't rear its ugly head.
It may also be worth noting that I replaced the stay and the furler with the mast up. It was really straightforward and I am not sure how possible this would be with eg an Alado.
Good hunting
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Leither is offline
post #12 of 13 Old 12-28-2008
Good hunting
Stuart
Okay, How about the rest of the rig? You stated "..it was very old and worn."
That caught my attention. Was the rest of the rigging replaced at a different time or does it look bad too?
BTW, If you have to add a toggle, and you want to use an existing forestay, it can easily be shortened with the use of a mechanical fitting.
knothead is offline
post #13 of 13 Old 12-28-2008
Retired and happy
Leither's Avatar
Interestingly, the rest of the rigging is fine - I have been over it thoroughly and can find nothing which suggest that there is a problem. I am pretty sure it is all the same age as the forestay. However, the previous furler had an aluminium foil which was in poor condition. In particular, it was kinked and the joints were beginning to spring. This seemed to have created wear points on the stay which were quite severe in places making it look "old and worn".
Stuart
Leither is offline
Old Roller Furler (a.k.a. "To Furl, or Not To Furl...") supergrade Gear & Maintenance 34 12-24-2008 11:36 AM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
