weird engine noise - Page 2 - SailNet Community
post #11 of 36 Old 12-28-2008
Barkeep - Sailor's Pub
craigtoo's Avatar
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
SD
I kinda liked my answer better. It was nicer and at least fixed his problem!
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
craigtoo is offline
post #12 of 36 Old 12-28-2008
JR...
Start your motor, and get your other half to reproduce the symptoms, however you do it.
Go round the motor listening carefully until you get an idea of where it's coming from.
Screeching is normally a belt drive issue, but it should not happen to the alternator belt if the batteries are well charged.
Check the belt tightness.
Which motor is it? Do you have a picture or a reference?
Is there enough lube in the gearbox? Sometimes a 'box can make a funny noise going on and off load.
Generally, if it is not a clattering, the motor should be fairly sound.
Rockter is offline
post #13 of 36 Old 12-28-2008
Anything-Sailing Founder
ckgreenman's Avatar
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
Originally Posted by craigtoo View Post
SD
Well, it doesn't fix the problem but it does fix the complaint
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
ckgreenman is offline
post #14 of 36 Old 12-28-2008
ckgreenman's Avatar
Originally Posted by Rockter View Post
JR...
That's pretty much what I was thinking. I don't know of anything else that would make a screeching sound. I would definitely check to motor mounts. Also look around the pullyes on the front of the engine, is there anything in close proximity? Does it show wear that might be cause by rubbing against a pulley?
And as others have said, details of the engine and driveline would help as well.
Chris
1975 O'Day 25
Meet me at
post #15 of 36 Old 12-28-2008
Retired and happy
Leither's Avatar
On the basis that diagnosis involves eliminating the simplest possible causes first, then I would agree with those who advocate checking drive belts. If the alternator belt is the cause, then you should be able to reproduce the noise by starting with the engine at a fast tickover with no batteries connected, then switching in both batteries. The charging load on the alternator should result in a screech from the slipping belt.....
Good hunting
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Leither is offline
post #16 of 36 Old 12-28-2008
Irrationally Exuberant
Man, JR...., I have to go with Sailingdog & Cardiac and say, give some information, for crying out loud! It's not like everyone is right there in the boat with you.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #17 of 36 Old 12-28-2008
bljones's Avatar
JR...
Start your motor, and get your other half to reproduce the symptoms, however you do it....
We're still talking about a boat problem, right?
bljones is offline
post #18 of 36 Old 12-28-2008
Retired and happy
Leither's Avatar
I'm really glad someone else picked this up. I cracked up reading it (no offense, Rockter) assuming it related to some form of mating ritual. Though, I must admit, " 'box" is not a term I am familiar with in this context.......
Stuart
Leither is offline
post #19 of 36 Old 12-28-2008
ckgreenman's Avatar
Stuart
OMFG. I just picked up on that one.
Anyway, as for the switching the batteries in and out. You really should be careful. Most alternators I know of are likely to blow the regulator if you disconnect the batteries while the engine is running.
Chris
1975 O'Day 25
Meet me at
post #20 of 36 Old 12-28-2008
craigtoo's Avatar
Bahaha! Point Mr. Jones.
Aweome. !
Where the heck is JR?
-C2
Meet me at the
I love
craigtoo is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
