Low buck projects- Let's see 'em! - Page 100 - SailNet Community
 1223Likes
post #991 of 1560 Old 02-24-2014
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Re: Low buck projects- Let's see 'em!
Originally Posted by This Old Sailboat View Post
Just completed the classic companionway hatch repair using masking tape. Total cost about $3 in materials and a couple of hours.
For the whole story on stopping the screeching, see the latest post in my blog.
might I suggest using graphite powder mixed with the epoxy for lower friction
Bill-Rangatira is offline
post #992 of 1560 Old 03-10-2014
Dave_E's Avatar
This is my first post to this thread. The boat has an integral fresh water tank made in the bow under the V berth. The first time we ran out of water (at the dock) I started looking... there was nothing to indicate water level and no way to have a look at the tank. I cut a hole on top of the tank, (which is under the V berth cushions) and installed a 12" access plate. That's good for maintenance, but still didn't solve the water quantity issue without moving cushions and opening the access. (I'm lazy). So I built the gauge setup shown below. Paid $40 for the gauge and $25 or so for the plumbing. The gauge reads "inches of water". The wife watched and recorded the gauge as I added 1 gallon at a time and then made a conversion table. Works good.
Faster, fryewe, Bene505 and 3 others like this.
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
The Following User Says Thank You to Dave_E For This Useful Post:
randyrhines (03-10-2014)
post #993 of 1560 Old 03-10-2014
Dave_E's Avatar
Here's another. Not that folks haven't installed microwaves, but I see them all over the boats. Our galley cupboards were perfect. We have CNG for the stove/oven, plug in coffe maker and hot cups, all we needed to round out the galley was a microwave. $89 or so on sale and cut one shelf... fit like a glove.
bljones and Group9 like this.
GOD, Family, career
Dave_E is offline
post #994 of 1560 Old 03-10-2014
txg
That's a quite nice idea, but there is another option, using a "flow counter" (don't know how they are called exactly in english) like this one (german page):
GARDENA Wassermengenzähler
those are available for about 20 Bucks, and you can simply put them in the line to the sink. Then, fill the tank, empty it and you know the exact tank volume.
pros:
-cheaper and easier to install
-very accurate
cons:
-you have to reset the counter when you refill the tank
-doesn't work if you don't fill the tank completely
Ritchard likes this.
txg is offline
post #995 of 1560 Old 03-10-2014
Dave_E's Avatar
pros:
-very accurate
cons:
I looked at that, however unless someone tells me for sure that gravity is enough force to work the counter... I don't know how sensitive they are. Not a bad idea if it works. It would probably work downstream of the pressure pump, but I had no room to install something in the plumbing that I could readily get to (everything behind walls or under floors).
GOD, Family, career
Dave_E is offline
post #996 of 1560 Old 03-10-2014
Bill SV Rangatira
pros:
-very accurate
cons:
English link
GARDENA Water Smart Flow Meter - Hose connectors
post #997 of 1560 Old 03-10-2014
I can't imagine you can get cheaper, simpler nor easier than a sight tube
Multihullgirl is offline
post #998 of 1560 Old 03-10-2014
and, if I recall, graphite in the epoxy will also add UV protection, yes?
Bill-Rangatira likes this.
post #999 of 1560 Old 03-10-2014
Bill SV Rangatira
yes
or if you want something a little more wear resistant you could add aluminum to the mix
west additives are great even if their epoxies are over priced /over rated
SloopJonB likes this.
post #1000 of 1560 Old 03-11-2014
Closet Powerboater
MedSailor's Avatar
While most all small microwaves appear to be the same size, there is one microwave on the market (that I am aware of) that is smaller than all the rest. I used to own a Sharp Half Pint, and it is a good little microwave 600W and big enough for a dinner plate, but the guts of the thing were well arranged as to not take up much space at all. If you're considering putting a nuker on a boat, take a look at this little puppy as it can save some space.
Sharp Half Pint Microwave
MedSailor
PS Happy 1000 posts to one of the best threads ever on SailNet!
MedSailor is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
