Low buck projects- Let's see 'em! - Page 102 - SailNet Community
 1230Likes
post #1011 of 1562 Old 03-30-2014
bristol299bob's Avatar
LED galley lighting
My boat has LED lighting throughout the cabin, but it was older tech and the color was too "cool" for my taste. Changing out most bulbs with newer "warm white" replacements was a 2 minute job and transformed the cabin from "harsh" to "cozy"
But the galley had those "puck" style under-cabinet lights. Not only were they the harsh blue/white color, but the coverage was uneven, and there were only 2, not enough to light the entire galley. Here is the before:
these had to go!
I bought this LED strip light:
http://www.amazon.com/gp/product/B002Q907EW?ie=UTF8&camp=213733&creative=393177&creativeASIN=B002Q907EW&linkCode=shr&tag=eauciuen0a-20
And this:
http://www.amazon.com/gp/product/B00F9RW2UU?ie=UTF8&camp=213733&creative=393177&creativeASIN=B00F9RW2UU&linkCode=shr&tag=eauciuen0a-20
Since I was going to cut the 1M section and make two strips I ordered additional end caps and mounting clips for the channel (~$4)
The LED strip has 3M double sided tape on the back, so just peel it off and stick it to the channel. The strip can be cut to almost any length you desire. You can cut it every 3 LEDs, you can see the cut mark in this picture (just above the bottom-most LED)
You can solder your leads to the pads on either side of the cut. I cut a few 3 LED segments to practice soldering it. It takes a light touch since the strip is small and thin. It heats up very fast and can be damaged if it get too hot.
Here's the result, for under 30 bucks:
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
The Following 7 Users Say Thank You to bristol299bob For This Useful Post:
Bill-Rangatira (03-31-2014), mcgray (12-31-2014), nightowle (06-09-2014), randyrhines (03-31-2014), ravinracin (03-31-2014), tschmidty (03-31-2014), wmmulvey (03-31-2014)
post #1012 of 1562 Old 03-31-2014
aka $tingy Sailor
This Old Sailboat's Avatar
Re: Low buck projects- Let's see 'em!
Well done!
Explore over 100 DIY sailboat restoration and improvement projects at
This Old Sailboat is offline
post #1013 of 1562 Old 03-31-2014
Randy Hines
randyrhines's Avatar
Re: LED galley lighting
these had to go!
Amazon.com: LEDwholesalers 16.4 Feet (5 Meter) Flexible LED Light Strip with 300xSMD3528 and Adhesive Back, 12 Volt, Warm White 2700K, 2026WW-27K: Home Improvement
And this:
Amazon.com: 1M/3.3ft Shallow Flush Mount Aluminum Channel U-Shape for flex/hard LED Strip Light w/Oyster White cover-U03: Home Improvement
Very nice good tip , good job!
randyrhines is offline
post #1014 of 1562 Old 03-31-2014
GeorgeB's Avatar
I like your task lighting! Where did you run the wires and where did you mount the switch? Do you have "red" lights already mounted in the galley area?
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #1015 of 1562 Old 03-31-2014
I reused the switches from the old lights, a simple low profile rocker switch right next to each light. they are white switches so they blend in. All of the wires run behind the liner. Above the sink there is a large space space behind the liner, plenty of room to wire and I already had a fuse block there. Above the stove its a little tight and it required a bit of fishing and snaking of wires.
I have red lights in the Nav area but not in the galley ... yet :-) But you bring up a good point. There are few options for red:
1 - Add another strip of red LEDs
2 - Use 3 conductor LED strip lights that can display any color. Could be programmed to display white or red with a DPDT toggle.
Red lights:
http://www.amazon.com/gp/product/B002Q8YRYY?ie=UTF8&camp=213733&creative=393177&creativeASIN=B002Q8YRYY&linkCode=shr&tag=eauciuen0a-20
multicolor lights:
http://www.amazon.com/gp/product/B0040FJ27S?ie=UTF8&camp=213733&creative=393177&creativeASIN=B0040FJ27S&linkCode=shr&tag=eauciuen0a-20
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
post #1016 of 1562 Old 03-31-2014
GeorgeB's Avatar
Thanks for the info. My galley really needs task lighting and I was trying to figure out where I could get a low profile fixture that didn’t cost an arm and a leg.
George B
Alameda, Ca.
GeorgeB is offline
post #1017 of 1562 Old 04-05-2014
aka $tingy Sailor
If you're looking to add more storage space in the cabin, check out the latest post on my blog, Under galley storage solution. If you're handy with wood or know someone who is, you can make exactly what you want quite economically, about $11.50 in my case .
bristol299bob likes this.
post #1018 of 1562 Old 04-05-2014
Learning a bit every day
FinallySailing's Avatar
Nice job and very interesting blog !
Yet my heart hammers now, yearning anew
wanting the steep salt-water road
longing with lust to roam rough seas, alone
to seek out some far foreign shore
From "The Seafarer", an Anglo-Saxon 10th century manuscript.
FinallySailing is offline
post #1019 of 1562 Old 04-12-2014
ericb760's Avatar
It's impractical to pull my outboard after each use, so I leave it in on the weekends. I figured it would be better if I painted the lower unit with zinc chromate primer. Cost me $16.00 on Amazon.
ericb760 is offline
post #1020 of 1562 Old 04-14-2014
Closet Powerboater
MedSailor's Avatar
I had a neighbor, when I was living aboard, that solved the problem with a $10 plastic office-sized wastebasket. He would strap the plastic wastebasket to the lower unit and lower it into the water, thus keeping it bone dry. He would occasionally have to pump out rainwater, but that's fresh water anyway.
MedSailor
MedSailor is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
