Low buck projects- Let's see 'em! - Page 103 - SailNet Community
 1223Likes
post #1021 of 1560 Old 04-14-2014
no longer reading SailNet
Alex W's Avatar
Re: Low buck projects- Let's see 'em!
Yesterday I made a cheap mount for my Raymarine i70 using a Bud PN-1337-DG water-proof enclosure. This cost $9 from Amazon. The Bud PN-1336-DG would be a little nicer looking and lower profile, but for some reason those are $28 from Amazon.
First I drilled the 80mm (3-1/4") hole for the instrument and 4 pilot holes for screws. I did this on a small CNC mill, but it is an easy job on a drill press:
I mounted it using a RAM ball mount on the back of my seahood (over the companionway). I already had this lying around, but they are about $20-$30:
Note that the case is fully closed in that photo, even if it doesn't look like it. There is an O-ring seal around the inside edge to keep it waterproof.
This is the final product:
You need to take the bezel off of the i70 to get good access to the 4 screws that close up the case.
I like having this instrument mounted over the companionway. You can see it from anywhere in the cockpit and I rarely push the buttons so there is no reason to have this on the pedestal.
I think that this looks nicer than a NavPod and it's a whole lot cheaper:
Navpod PowerPod Grand Prix Series
Alex W is offline
post #1022 of 1560 Old 04-14-2014
Glad I found Sailnet
Bene505's Avatar
Re: LED galley lighting
Originally Posted by bristol299bob View Post
My boat has LED lighting throughout the cabin, but it was older tech and the color was too "cool" for my taste. Changing out most bulbs with newer "warm white" replacements was a 2 minute job and transformed the cabin from "harsh" to "cozy"
Can you update the links? They don't work, and that would be perfect in our galley.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #1023 of 1560 Old 04-15-2014
faiaoaehe's Avatar
Great ideas
Sent from my HUAWEI-M931 using Tapatalk
faiaoaehe is offline
post #1024 of 1560 Old 04-15-2014
bristol299bob's Avatar
Regards,
Brad
I'm not entirely sure why those amazon text links don't work, but click on the picture below it and you will get there.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #1025 of 1560 Old 04-17-2014
rhr1956's Avatar
I made a drill brush for cleaning the non-skid areas of the boat. It took about five minutes and less than $3.00 plus it works GREAT!
HDX Soap and Scrub Kitchen Brush-139HDXRM at The Home Depot
1. Pop the top off. (I used my vise to break the soap holder off the brush part. 2. Thread a 1/4 - 20 screw (about 2 - 3 inches long up through the hole in the center of the brush head. 3. Secure the screw to the head with two 1/4-20 nuts, the second nut acting as a lock nut. 4. Insert assembly into the chuck of your favorite drill and start scrubbing using your favorite cleaner.
rhr1956 is offline
post #1026 of 1560 Old 04-26-2014
aka $tingy Sailor
This Old Sailboat's Avatar
Am I the only one who thinks that mast gates are overpriced? I made a set myself for about the cost of a cup of coffee at Starbucks. It wasn't that difficult and they work fine.
Mast gates solution | The $tingy Sailor
AllThumbs likes this.
Explore over 100 DIY sailboat restoration and improvement projects at
This Old Sailboat is offline
post #1027 of 1560 Old 04-26-2014
midlife crisis member
AllThumbs's Avatar
I added a DIY rub rail to my dinghy. 3/4" nylon double braid. Fastened with a #6 flat head SS screw every 4" after first pulling the line as tight as possible. The screws are driven through the outer layer into the core so they don't show. Price: $35.
I also made those nylon bushings for the oar locks so it was no longer metal on metal. That requires a lathe so it doesn't count.
I sail.
AllThumbs is offline
post #1028 of 1560 Old 04-27-2014
Barquito
Barquito's Avatar
$tingy- Those are great! For those that are not trailer sailing, using a flathead screw rather than a knob will prevent lines catching on the knobs. Really nice stuff $tingy.
Valiant 32
Barquito is offline
post #1029 of 1560 Old 05-01-2014
AllThumbs's Avatar
I am going on a week long cruise on the North Channel next week (if the ice is off by then). It's a 16 foot boat with no electrical. I built this little battery box to keep my phone charged. It has two 12 V outlets so it can be charged by a small solar panel while the phone is plugged in. It is also capable of charging my hand held radio. Total cost was $10 for three 12 V plugs. I had everything else laying around.
I still need to add a couple screws to hold the lid on.
I sail.
post #1030 of 1560 Old 05-01-2014
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Nice little battery boxes. I have 4 of those batteries (7 ah) sitting at home that I got for free. I saw some people throwing a bunch away that were from computer UPS boxes and grabbed a few. They do come in use.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
