Low buck projects- Let's see 'em! - Page 104 - SailNet Community
 1230Likes
post #1031 of 1562 Old 05-01-2014
No more curry buffets
Ritchard's Avatar
Re: Low buck projects- Let's see 'em!
Nice enough battery box, but a week-long cruise in the North channel on a 16 ft boat in a week?! I am not worthy.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #1032 of 1562 Old 05-02-2014
midlife crisis member
AllThumbs's Avatar
Added a fuse and fastened down the lid. All done now.
I sail.
AllThumbs is offline
post #1033 of 1562 Old 05-13-2014
Raymond07's Avatar
I'm attending to a small job today, to replace the cabin fluoro light which has stopped working. It's not worth my time to analyse why it doesn't work - it could be wiring, a blown tube, any number of things, but really I don't want a fluorescent fitting in the boat, for a couple of reasons.
I figured I'd try replacing it with an LED fitting. The fittings available off the shelf look incredibly daggy, so I've bought one roll 5050 led strip, which is a thin, narrow flexible strip with a self-adhesive backing. I am intending to mount it on the fwd face of a deck beam, out of the way of everything and no fluoro fitting to bang my head on. The strip can be cut down to any length if there is too much light coming from it.
The first job is to test the wiring while the old fitting is in place, then remove the old fitting and test the LED strip, and nominate a new location for it. First job, test the wiring. Switch on the master switch, and test that power is on in the boat. Yep, the bilge pump makes its noise just fine. witch the power to the old light, via the main switch panel. Switch the old light on, just in case, and yes, now that I have the LED strip sitting in the cabin with me, the old fitting lights up like new.
Raymond07 is offline
post #1034 of 1562 Old 05-13-2014
Ritchard's Avatar
I'v used some of that LED strip lighting, it works great. It's more for accent light than task light, as there's not enough intensity for tasks. Pay attention to polarity - the strips will not work if wired backward.
Incidentally, I liked that strip lighting so much on the boat that I am replacing the old under-cabinet fluorescents in my kitchen with the same stuff. Much nicer light, and you could basically leave it on all the time as it uses next to no no electricity.
You can buy the stuff astonishingly cheaply on eBay. There are guys in China that will sell the stuff for peanuts, often with free shipping. I just pick someone with good feedback ratings and go for it.
Ritchard is offline
post #1035 of 1562 Old 05-14-2014
Lee Valley Tools has some nice channels with diffusers that are inexpensive.
LED Channels and Diffusers - Lee Valley Tools
They are local to us in Toronto so you can actually touch and feel before buying. And Lee Valley is not known for sourcing crap.
jimgo and Delta-T like this.
1981 Edel 665
Dock C, Lake Front Promenade
i_amcdn is offline
The Following User Says Thank You to i_amcdn For This Useful Post:
Delta-T (05-14-2014)
post #1036 of 1562 Old 05-14-2014
bristol299bob's Avatar
I'v used some of that LED strip lighting, it works great. It's more for accent light than task light, as there's not enough intensity for tasks. .
I find the strip lighting ideal for task lighting:
I got my diffusers and LEDs from Amazon:Galley lighting
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #1037 of 1562 Old 05-14-2014
Ritchard's Avatar
Wow, those Lee Valley diffusers are gorgeous.
Ritchard is offline
post #1038 of 1562 Old 05-26-2014
no longer reading SailNet
Alex W's Avatar
My boat doesn't have a gimbal for the stove. I wanted a very basic one that could be used to make coffee (or other hot water based items) under way. I had a Jetboil that I use for camping that was sell contained, efficient, and fast, so I decided to make a gimbal for it.
There is a quick video showing the range of motion here:
http://1drv.ms/1ikmPFe
It is all made of stainless steel. I used stainless pipe cut into 1" sections for the two rings, stainless 1/8" rod to make the basket that supports the stove, and stainless hardware that bolts it all together. All of it is 316 except for the larger pipe which I could only get in 304.
It is pretty crudely made mostly with a hand drill. I did braze the basket that holds the stove together.
The Jetboil has very little waste heat, so the items nearby are safe. This location lets me keep an eye on the stove while sailing the boat. It pops off for storage in a couple of minutes using the two quick release clamps.
I still have to polish up some of the stainless and trim off the excess starboard that was used to make the mount.
bljones, Group9 and fred1diver like this.
Alex W is offline
post #1039 of 1562 Old 05-26-2014
Ritchard's Avatar
When you want your damned coffee right now!
Ritchard is offline
post #1040 of 1562 Old 05-26-2014
Senior Moment Member
SloopJonB's Avatar
But..but..how do you get the winch handle out without burning your hand?
SloopJonB is online now
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
