Low buck projects- Let's see 'em! - Page 106 - SailNet Community
 1223Likes
post #1051 of 1560 Old 06-07-2014
aka $tingy Sailor
This Old Sailboat's Avatar
Re: Low buck projects- Let's see 'em!
Don't know if it technically qualifies as a low-buck project because if you DIY, it shouldn't cost over $100 but I refinished my exterior and companionway teak woodwork this past winter for around $60. Here's a link to the post on my blog. There's a few unusual points in it like simple jigs for varnishing parts, adding epoxy edge armor on the crib boards, and replacing the lock hasp for a cylinder lock, so I hope you find some useful ideas.
Enjoy!
$tingy Sailor
mcgray, dvuyxx, Group9 and 2 others like this.
Explore over 100 DIY sailboat restoration and improvement projects at
This Old Sailboat is offline
post #1052 of 1560 Old 06-09-2014
Sailor of Small Waters
The Vagabond 14 I just bought almost qualifies as a low-buck project as a whole at $600 for boat and trailer, but like most cheap boats it needed some repairs before getting it wet again. The original rudder (and centerboard) had rotted and the previous owner had replacements made by a local cabinet maker, templeted from the originals and using the original hardware. I'm not sure what happened to the original tiller, but the replacement was an 18" piece of 1'x2" red oak that had been cut into a long thin triangl. The front end was barely 1/4" thick, ramping up to 2" at the back. It was far too short and flimsy to work the linkage that kicks up the rudder, so I needed a new tiller. I really wanted one of the pretty, formed, laminated wood ones but I'm not putting a $100 tiller on a $600 boat.
My answer? A beautifully formed, solid piece of American Hickory. Specifically, a $10 replacement axe handle from the local hardware big box. With a little cut-and-fit on the blade end to fit it into the rudder assembly, I think it will work great. It's a little bulky for such a small boat, so I may go back and trim the end handle a bit. I'll probably use it this summer and see how I like it, then hit it with some spar urethane this winter.
I'll post pics later, having trouble uploading currently.
EDIT: as promised, pic of the Ten Dollar Tiller:
1981 Vagabond 14 "Firefly"
196(8?) Douglas & Mcleod Thistle #2694 "Old Dog"
Jack Sparrow think's I'm a Commodore
Why does everyone think my name is Clyde...?
ultraclyde is offline
The Following User Says Thank You to ultraclyde For This Useful Post:
Multihullgirl (06-10-2014)
post #1053 of 1560 Old 06-13-2014
aka $tingy Sailor
A complete, commercially produced bimini top for my C22 for under $100 shipped I added some extras to it that pushed my total installation cost to over $100, but if you want to do a stationary installation, no additional purchases are necessary.
All the details and more pictures are on my blog in Budget bimini top solution.
Cheap shade!
post #1054 of 1560 Old 06-13-2014
Senior Moment Member
SloopJonB's Avatar
I'd leave it alone - the axe handle end has a certain style.
SloopJonB is offline
The Following 2 Users Say Thank You to SloopJonB For This Useful Post:
Daydreamer22 (06-23-2014), Multihullgirl (06-13-2014)
post #1055 of 1560 Old 06-13-2014
Dock
I'm contemplating the same solution, actually. I just have to slice off the tapered back end to give enough width to mount on my rudder cap, but I do find it's a unique style indeed.
1970 Islander Excalibur 26 - Retired
CharlzO is offline
post #1056 of 1560 Old 06-16-2014
Thanks. I did cut off the tapered part that normally goes into the axe head, and I cut and sanded what is now the top & bottom to make a flat surface for mounting hardware.
I took the boat out for the first time yesterday. It works pretty well, but it could have been about 8" longer to be perfect. Time to go back for that rake handle and make a hiking stick...
SloopJonB and aelkin like this.
post #1057 of 1560 Old 06-21-2014
shadowraiths's Avatar
Last year, to keep flying critters (especially bees) from flying into my cabin, I picked up some netting from the army surplus. Since that time I have been playing around with 3D printing. So, I decided to make a drop-in screen for my companionway. To do this, I am using a screen frame kit, with my own 3D printed corner brackets. I haven't put it together. Yet. However, I have checked to see if these things fit the frame (they do) as well as verifying the angles are correct (they are). Now it is a matter of cutting the thing to size, and installing the screen on the frame. Following is the cost breakdown (sans tax):
Screen Kit: $15
Black nylon screen: $5
Printed Brackets: 22 grams ( ~ 75)
Total: $20.75
Here's a pic of the 3D printed brackets including a couple kit brackets for reference.
P.s. yeah, I know. Fluorescent green. I save my black & white filament for things like my raspberry pi / go pro mounting system.
Oh, and. Printing bots. Of course. ^_~
bandaidmd and YachtOgler like this.
shadowraiths is offline
post #1058 of 1560 Old 06-21-2014
s/v Tiger Lily
dvuyxx's Avatar
Cool. I can't wait until I'm 3D printing parts. The future is here!
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #1059 of 1560 Old 06-21-2014
SloopJonB's Avatar
I'm holding out for one that prints stainless steel parts.
ccriders and sailorboy15 like this.
post #1060 of 1560 Old 06-21-2014
I must admit, it's a blast. Here's a non-boating item I printed...
... for the challenge, of course.
As for printing marine items? I've been pondering various possibilities. There are some considerations, however. For example, PLA is biodegradable, since it's pretty much made from vegetable oil extracts. So, it would not handle the weather. ABS, isn't. In fact, Legos are made from an injection molded ABS process. Otoh, FDM printing is much more rough than high-end 3D printing, as the melted plastic is laid down in layers. That, and the tensile strength is not that great for anything that depends on serious force (as most marine items, do). I have been experimenting t-glase, which can allegedly withstand a sledge hammer. The printed item's strength, however, depends upon two factors: tensile strength and layer adhesion. A too-hot t-glase print generates a fused mess. While too-cool prints result in parts that break apart at the layers.
So, the abbrev of the above tl;dr?
Printing things like screen brackets, curtain mounting blocks... basically things that can deal with odd-boat shapes, and even a few of those plastic pieces you find at hardware stores (i.e., spacers, etc), is great. Printing things that can withstand forces and weather? Not so much.
Yeah, that would be really nice. One guy is working on designing a metal extruder, though he's using solder for his filament. Would be interesting to see how far he gets. In the meantime, printing services, such as shapeways, who offer metal prints, use the lost wax process. Primarily bc, the challenge with metal printing is similar to that of t-glase: layer adhesion. Lost wax removes that from the equation.
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
