Low buck projects- Let's see 'em! - Page 107 - SailNet Community
 1230Likes
post #1061 of 1562 Old 06-21-2014
Senior Moment Member
SloopJonB's Avatar
Re: Low buck projects- Let's see 'em!
It's all just magic to me - a Star Trek replicator.
SloopJonB is online now
post #1062 of 1562 Old 06-22-2014
There are machines that can do structural metal printing but they are still in the 200k range. Maybe some day.
Greg
Stumble is offline
post #1063 of 1562 Old 06-22-2014
TakeFive's Avatar
Here's a quick fix for a poorly performing cheek block.
I have single line reefing, and unlike many, I like it. I've managed to take much of the friction out of the system with a block at the tack cringle so I can usually reef without going forward. Frankly, 90% of the time I decide whether to reef before leaving the slip, so reefing under way is minimized.
But when I do reef, one frequent problem occurs with the little cheek block on my mast. This block takes the line from the boom and diverts it upward to the reefing cringle at the luff. That works fine as long as tension is maintained, but there are many cases where the loss of tension when under full (un-reefed) sail causes the reefing line to fall off the cheek block and later get fouled when tensioned. Ignore the white/green line in the picture below - that's a spare halyard that I lashed around the mast to keep it out of the way. The reefing line is the white/blue one:
I decided that the reefing line would stay put even when not under tension if I made a guide to put over top the cheek block:
The guide piece is made from 1/8" thick HDPE cutting board that I've used for various small projects. I used a hole cutting bit to make the round piece.
Rick S., Swarthmore, PA
TakeFive is offline
post #1064 of 1562 Old 06-23-2014
no longer reading SailNet
Alex W's Avatar
The 3D printed parts reminded me of one of my recent projects, a simple bracket to hold a high gain wifi antenna to my shrouds.
I made the plastic bracket, it is cut out of a piece of starboard. I used my Taig CNC mill for the work, but a functional one would be easy to make using hand tools too. The loops top and bottom are for tying it onto the flag halyard, so that I can run it up to spreader height for use. When I don't need it the whole assembly is stored safely below decks instead of being permanently mounted.
I used it for the first time on Friday night when we were staying at Poulsbo Marina. My laptop and a couple of tablets could see but not connect to the marina WiFi from inside the cabin. Using the WiFi repeater (a Mikrotik Groove 52HPn) and that large antenna gave us a strong and fast signal.
I'll point out that CNC mills make it pretty easy to manufacture custom shaped 3D items out of stainless steel. Their are advantages and disadvantages to both additive ("printing") and subtractive ("milling") processes, but right now milling is the only affordable solution to making custom metal parts from computer drawings at home. The CNC mill cuts plastic just fine too.
ericb760 likes this.
Alex W is offline
post #1065 of 1562 Old 06-23-2014
Back when I was casting bronze bits and cannons (aluminium too) the mould was always a tedious part. Seem to me a 3D printed part in wax would be a great asset to lost wax casting
MedSailor likes this.
Capt Len is online now
post #1066 of 1562 Old 06-23-2014
SloopJonB's Avatar
And all this time I thought having my own drill press was pretty cool.
post #1067 of 1562 Old 06-23-2014
Minnesail's Avatar
I don't even have a drill press anymore, I burned out the motor using a 6" hole saw on it to cut a G10 backing plate
Catalina 22
on a starboard tack
Minnesail is online now
post #1068 of 1562 Old 06-23-2014
Alex W's Avatar
For the five years before sailing I spent a lot of my hobby time and money building bicycle frames and tooling. As a result I have a fairly complete (for a hobbyist, not a pro) metal shop in my basement. I'm always glad when I get to apply some of those tools to boats.
My blog (Alex Wetmore is always busy with something?) has lots of information on those projects. Here is an example project with far more machining:
Alex Wetmore is always busy with something? » Blog Archive » My new frame fixture
Some bicycle framebuilding tools that I sold helped cover the costs of my CNC mill:
Alex Wetmore is always busy with something? » Store: Framebuilding Tools
bristol299bob likes this.
Alex W is offline
post #1069 of 1562 Old 06-24-2014
Closet Powerboater
MedSailor's Avatar
This is cheating I know, because I haven't done the project yet, and because the video isn't mine. However I plan to do this tomorrow to add cheap AC to my man-cave. I thought y'all might like it because it looks like cheap and effective boat AC and ice is often available.
MedSailor
mbianka likes this.
MedSailor is offline
post #1070 of 1562 Old 06-24-2014
Daniel - Norsea 27
Rhapsody-NS27's Avatar
MedSailor
Attached is my version I did a couple days ago. HVAC does work right now and the temps inside the house got up to 89. When I did this, it lowered the temp about 5 degrees before it went back up but by then, it was dark outside and cooled down overnight. The way it's setup in the picture, the box fan is blowing up to try getting the cooler air circulating along with the ceiling fan. The ice melted pretty fast though.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
