Low buck projects- Let's see 'em! - Page 112 - SailNet Community
 1223Likes
post #1111 of 1560 Old 08-12-2014
Re: Low buck projects- Let's see 'em!
Thanks
I have been happy with it - you could make it a different size if you want.
I store the table aft on port with the fenders - see the background of the picture - the table top goes to the hull to keep it clean, some of the fenders usually end up going against the bottom of the table when the table is stored
nwsaildude is offline
post #1112 of 1560 Old 08-13-2014
I make sawdust
thereefgeek's Avatar
Outboard engine stand. Basically free since I already had the 2X4's and wood screws. Built from a set of plans downloaded off the inter webs, and it has a spot to put your gas can, and you can park a rubbermaid tub full of water under the lower end for a test run.
test run from Ramble On on Vimeo.
-Rich VanDusen
1977 Tayana 37 Hull #91
Ramble On
thereefgeek is offline
post #1113 of 1560 Old 08-13-2014
I make sawdust
Nice work bench!! I'm jealous.
Originally Posted by deniseO30 View Post
this really is low buck since the beech lumber was free. I have less then a $100 in hardware including the tail vise slide that was on sale for $55.
More pics here;
http://www.sailnet.com/forums/off-to...ml#post1204401
-Rich VanDusen
Ramble On
post #1114 of 1560 Old 08-13-2014
I make sawdust
Nice score on the bronze port lights. We cleaned ours with a soak in Clorox toilet bowl cleaner (the blue kind with HCl, not chlorine). The acidic nature of the cleaner is a bit of a pain to work with, but we wore gloves and safety glasses when scrubbing with a brass brush. After paying $25/ea for new laminated safety glass for 8 oval and 3 round ports on our T37. I'm not sure it qualifies as a "low buck project", but at $3 for a bottle of Clorox, it's a cheap way to remove a whole lot of scale and corrosion from bronze hardware in a real hurry…
I have to crib this a bit in order to qualify for the low buck category. I'm only going to show 10% of the total project. I got ten of these solid bronze opening ports for $60 each. I had to scavenge them from a derelict old cruiser to get them for that price and by the time I was done I already wondered if I had paid too much.
The boat I recently bought has plastic deadlights with brass trim rings outside and teak rings inside. I wanted metal opening ports but even brass ones would have cost several boat bucks - bronze ones like these would have been almost as much as I paid for the whole boat plus they would have to come from New Zealand.
It's taken about a full days work each to remove, clean & polish them. That adds up when there are 10 of them to do. I had to start with 220 sandpaper and go up through 320, 400, 600, 800 & 1200 before I could begin buffing but I'm pretty happy with how they came out and especially the deal I got.
They won't go in until next fall or winter.
Before & after pics below.
-Rich VanDusen
Ramble On
post #1115 of 1560 Old 08-13-2014
I make sawdust
We also use Flitz metal polish every 6 months or so to maintain that "shiny new, straight from the factory" bronze finish. Not bad for bronze ports founded in 1977….
-Rich VanDusen
Ramble On
post #1116 of 1560 Old 08-13-2014
midlife crisis member
AllThumbs's Avatar
I cut the four holes on the sides of the berths for easier access. There are hatches on top but these are a pain with the cushions and who knows what else on top (sometimes people). I used a 3" hole saw to create the radii and then joined the holes with a thin cut off disk in an angle grinder. Finished it up with some sandpaper to remove sharp edges.
I sail.
AllThumbs is offline
post #1117 of 1560 Old 08-13-2014
Senior Moment Member
SloopJonB's Avatar
Are those pics simply before & after the acid bath or did you polish them up after?
Also, where were you when I spent all those days with wire brushes, sandpaper, buffing wheels & metal polish?
SloopJonB is offline
post #1118 of 1560 Old 08-13-2014
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Nice work.
I've used vinegar to clean parts that still turned out well. Those ports of yours now looks brand new.
nighthawk likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #1119 of 1560 Old 08-14-2014
69' Coronado 25
socal c25's Avatar
Dock
You can finish the cut-outs with automotive door edge guard to kkp your hands and arm from rubbing against the fiberglass, it makes a softer edge.
MedSailor likes this.
"There're those that stand at the shore looking to the sea, wondering, and there're those standing at the helm looking back at the shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
post #1120 of 1560 Old 08-14-2014
Singlehander by Default
nighthawk's Avatar
Like the cutouts. And if you can find a local upholestry shop you the will probably carry that rubberized edge strip that slips on over the edges. They normally sell it by the foot, so you can cut it to exact length insted of trying to piece together door edging to make it fit all the way around. A little dab of glue or sealant in places ans it will stay in place for years.
Spencer
Laguna Windrose 22 "Wind Angel"
Catalina 16
Visit my blog--
~~When you decide to become a sailor, you start with a full barrel of luck and an empty cup of experience. The trick is to fill your cup before the barrel runs dry.~~
nighthawk is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 02:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 05:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 08:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
