Low buck projects- Let's see 'em! - Page 113 - SailNet Community
 1223Likes
post #1121 of 1560 Old 08-14-2014
Re: Low buck projects- Let's see 'em!
I have also seen the edging in Marine Supply stores also
nwsaildude is offline
post #1122 of 1560 Old 08-14-2014
mitiempo's Avatar
Taco makes edging that should be available in any good marine store. As posted the automotive trim works well also.
Brian
mitiempo is offline
post #1123 of 1560 Old 08-17-2014
I just relabeled my electrical panel. Not only was it nearly illegible, several of the labels were confusing or downright wrong, as I think you'll agree:
The labels came off rather easily with a razor blade, then I did a little cleanup with Goo Gone and alcohol.
I had the stickers made up by a local sign shop. They're printed on clear plastic (vinyl?), since the cut out letters used for larger stuff like boat names would have been too tiny to deal with. I chose to accentuate the circuits that are powered by the inverter by making them blue. The total was $55, and was the only cost for this project, aside from about an hour and a half of time. The observant among you may note that I swapped out my voltmeter for a TriAnchor light control, since that function is now performed by my battery monitor, so there was no need to label that now-defunct switch.
Finished product:
Much more legible, and now I don't have a LORAN breaker anymore!
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #1124 of 1560 Old 08-17-2014
Nice job on the panel
post #1125 of 1560 Old 08-17-2014
69' Coronado 25
socal c25's Avatar
Dock
very pro looking
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
post #1126 of 1560 Old 08-18-2014
On the subject of sourcing, McMaster-Carr is an industrial supply house not unlike Grainger. McMaster has an excellent online search engine which includes data on the materials in question. There is no minimum and their prices are competitive to low.
I'm quite sure the trim pieces will be there. I've bought bearings for traveler tracks and winches, rivets, gasket material, sheet and billet plastics and metals, filter/strainers, cork for flooring, the list goes on and on
the website is mcmaster.com and it's a wonderful resource.
Multihullgirl is offline
post #1127 of 1560 Old 08-18-2014
Glad I found Sailnet
Bene505's Avatar
Originally Posted by AllThumbs View Post
I cut the four holes on the sides of the berths for easier access. There are hatches on top but these are a pain with the cushions and who knows what else on top (sometimes people). I used a 3" hole saw to create the radii and then joined the holes with a thin cut off disk in an angle grinder. Finished it up with some sandpaper to remove sharp edges.
You could velcro something against the "walls" to cover the holes.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #1128 of 1560 Old 08-18-2014
Making Pelican Hook Lanyards & Key Fobs
These are Lanyards I have made for my boat and for friends, they also work nice as Key Fobs (Gave many Key Fobs away as gifts)
They are quick and easy - use colorful line - or Red & Green for Port & Starboard - install them backwards on your friends boat if you are in a bit of a mean or joking mood.
This knot goes by many names, Portuguese Sennit, Cobra Knot, Solomonís Bar, Boatswains Plait and probably some others.
Instructions:
Making Pelican Hook Lanyards & Key Fobs | Boating Safety Tips, Tricks & Thoughts from Captnmike
Making Spiral Pelican Hook Lanyards & Key Fobs | Boating Safety Tips, Tricks & Thoughts from Captnmike
post #1129 of 1560 Old 08-19-2014 Thread Starter
bljones's Avatar
A digest of NextBoat's low-buck projects:
Dock Six Chronicles: Low-Buck Projectapalooza
It's 5 o'clock somewhere:
bljones is offline
post #1130 of 1560 Old 08-20-2014
I make sawdust
thereefgeek's Avatar
Are those pics simply before & after the acid bath or did you polish them up after?
Originally Posted by Rhapsody-NS27 View Post
Nice work.
I've used vinegar to clean parts that still turned out well. Those ports of yours now looks brand new.
Thanks guys. Those port pics were after a once-over with Flitz. Ive tried vinegar on the bronze, but it seems to take forever and a day to soak off 38 years of "patina".
Something else I've tried, and it's way less toxic than the hydrochloric acid in the Clorox toilet bowl cleaner is a soak in CLR (Calcium Lime & Rust cleaner available at Home Depot). More aggressive than vinegar, yet less acidic than HCl. Don't use it on brass, but it works great on bronze. You should still wear gloves, and a Scotchbrite pad scrubbing helps speed things along. The metal turns pink in the soak after it cuts through the green and still needs a good rinse afterward, before a final polish with Flitz but here's a before & after using CLR on the cowl vents on our Tayana 37:
Check out my blog in my sig line...
SloopJonB and Rhapsody-NS27 like this.
-Rich VanDusen
1977 Tayana 37 Hull #91
Ramble On
thereefgeek is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
