Low buck projects- Let's see 'em! - Page 114 - SailNet Community
 1223Likes
post #1131 of 1560 Old 08-20-2014
Senior Moment Member
SloopJonB's Avatar
Re: Low buck projects- Let's see 'em!
What happens if you use it on brass?
SloopJonB is offline
post #1132 of 1560 Old 08-21-2014
Regular Member
KismetP362's Avatar
Originally Posted by Multihullgirl View Post
I'm quite sure the trim pieces will be there. I've bought bearings for traveler tracks and winches, rivets, gasket material, sheet and billet plastics and metals, filter/strainers, cork for flooring, the list goes on and on
Can you tell me/us more about the "cork for flooring"? If your original project was over $100 I'll promise to use the cork for an under $100 project and then post it here. I'm guessing you used the STRIPS but how did it look and more importantly, how well did it wear?
~Ryan
~Pearson 36-2
~Sunk, Salvaged, Refitted, Sailing!
KismetP362 is offline
post #1133 of 1560 Old 08-21-2014
Cork tiles are great. Look in Home Depot or similar flooring store. Looks good and wears well. It's not gasket stuff.
Capt Len is offline
post #1134 of 1560 Old 08-21-2014
McMaster has cork sheets in 4x8 foot size. Do a search for 'cork' and then 'sheet'. This one 9487K38 is the one in question. Oil resistant - the one for chalkboards won't do.
But.... have since done more searching and found a place in Maine that offers it cheaper. Google 'cork sheet' or similar to get results. Bangor Cork is the place
Haven't installed it yet, mainly because the companionway door has to come out to solve the leak that ate the old floor and it's damn near 100F out there so that little job gets to wait for cooler weather
Cork tiles are heavy. And, every one I've seen has a fiberboard backing that I'm not interested in putting in the boat. I've tried all sorts of samples from various mfg (I leave 'em overnight in a tray of water) and they all delaminated. Therefore I want just plain 1/2" sheeting.
Multihullgirl is offline
post #1135 of 1560 Old 08-21-2014
pdqaltair's Avatar
Rod holder from an outboard rail mount. Actually, I use this one mostly to hold a pair of short outriggers when not in use. Very cheap, doesn't spin on the rail, and doesn't mark the rail.
The rail mount came with the boat; I leave the outboard on the tender, on the davits.
bljones likes this.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Writing full-time since 2014
pdqaltair is offline
post #1136 of 1560 Old 08-21-2014
I make sawdust
thereefgeek's Avatar
Not sure, but since it said so on the label I'm hesitant to try.
Besides, who uses brass on a sailboat anyway?
-Rich VanDusen
1977 Tayana 37 Hull #91
Ramble On
thereefgeek is offline
post #1137 of 1560 Old 08-24-2014
TakeFive's Avatar
I made a fenderboard out of 2" schedule 40 PVC pipe. The pipe is actually about 3" OD, very thick, sturdy, and stiff. I bought a 10' length and cut it into two pieces and made two of them like this:
This is not any less expensive than a real wood fender board, but it assembles/disassembles and stores more easily. Since my cockpit lockers are all <5' long, I need to store it inside my cabin. I only like having clean stuff down there, and the PVC wipes clean a lot more easily than wood.
I only use these a few times a year when visiting Chesapeake marinas that have non-floating bulkheads with pilings, requiring me to have fender boards to keep my boat from getting bashed up. On the Delaware River everything is floating docks, for which I have teardrop-shaped fenders that work better for those but don't work at all against pilings.
I use this with 6.5"x23" fenders, so with the PVC pipe it holds the pilings about 9" away from my hull, so the rubrail and fragile hull-deck joint do not come close to the piling. A well-placed knot on each fender line and a couple wraps around the top of the fenders keep the pipe at the perfect location between the fenders. It all disassembles very fast for easy storage under the cabin settee.
The fender and pipe sizes work well for my 25' boat. Dimensions could be upsized for bigger boats.
Not sure I would trust PVC in a heavy storm, though. But not sure I'd trust a 2x10 board under those conditions either.
Rhapsody-NS27 likes this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
The Following User Says Thank You to TakeFive For This Useful Post:
Rhapsody-NS27 (08-24-2014)
post #1138 of 1560 Old 08-25-2014
I make sawdust
Here's one for you.
Everyone looses a halyard up the mast from time to time
I found a thing online for snatching a loose halyard from the mast head for about $30+shipping. I made one from a 2x4 and some eyebolts for about $3.
(actually, free since I already had all the stuff)
Here's a couple links to the write-up on my site, and a video of it in action:
Hal-yard-lujah - Tayana 37 - Ramble OnRamble On
More fun with rope - Ramble OnRamble On
DIY halyard retrieval from Ramble On on Vimeo.
dvuyxx and Westsailforever like this.
-Rich VanDusen
Ramble On
post #1139 of 1560 Old 08-25-2014
reefgeek,
your solution reminded me of this:
Potato Masher = Bosun?s Chair??
post #1140 of 1560 Old 09-03-2014
asdf38's Avatar
I'm already working on version 2 of this but there is certainly a good idea here:
asdf38 is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 02:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 05:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 08:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
