Like Tree280Likes
  #181
Old 03-21-2011
bljones has a spectacular aura about bljones has a spectacular aura about
One issue on almost every small boat is no room for a garbage can. Another issue on "Whiskeyjack" is the amount of dead space below the galley countertop. Think, mark, cut, trim, screw together a couple of pieces of scrap luan for a lid, sand, varnish, Ta-freakin' DAH!
BreakAwayFL likes this.
It's 5 o'clock somewhere:
  #182
Old 03-23-2011
S/V Lilo, Islander 32
IslanderGuy is on a distinguished road
Nicely done bljones! I have been thinking about doing this exact same thing for quite some time, but as of yet have not gotten around to it. Thanks for sharing, looks like it will work out well, and may encourage me to get to it this spring!
S/V Lilo
1964 Islander 32
Saint Helens, OR
  #183
Old 04-02-2011
sealover's Avatar
sealover is on a distinguished road
Low buck block to run halyard to cockpit. These little heavy duty blocks (hardware store calls them pulleys) are rated at over 400 lbs for 3/8" line. $6 each.
Keep the expenses low and the good times high.
S/V Over Easy
Venture 17
PA Freshwater / Chesapeake
  #184
Old 04-02-2011
sealover's Avatar
Low buck batten? I'm curious how this will hold up. But it doesn't get any lower buck than a free yard stick.
S/V Over Easy
Venture 17
  #185
Old 04-02-2011
GaryHLucas is on a distinguished road
That block is zinc plated steel. How much are you going to spend getting rust stains off your nice white deck? The previous owner of my boat used zinc plated screws to make a couple of simple repairs. You can't believe what it has cost me to repair the damage done when the screws rusted out completely! They all damaged the aluminum or stainless they were installed in.
Gary H. Lucas
  #186
Old 04-02-2011
scraph is on a distinguished road
That's not a pulley! That's a sheave.
1981 C&C 32
  #187
Old 04-04-2011
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Don't know what boat its going on, but 400 lbs for a halyard isn't much.
Merit 25 # 764 "Audrey"
  #188
Old 04-04-2011
sealover's Avatar
400 lbs is half the displacement of the whole dang boat!
S/V Over Easy
Venture 17
  #189
Old 04-05-2011
zz4gta's Avatar
hahaha, oops, didn't see it was a 17 footer. No worries.
  #190
Old 04-05-2011
Great idea- before you use it as a batten, though, give it a couple of coats of varnish to seal it, so that the existing finish doesn't stain your sails if it gets wet, and it won't rot as quickly.
You may post attachments
You may edit your posts
LEDs afloat GoodOldBoat Good Old Boat 27 03-21-2013 08:07 AM
Low buck bow thruster?? wildcard Gear & Maintenance 23 01-11-2009 08:57 AM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
SEO by vBSEO 3.6.1
