Low buck projects- Let's see 'em! - Page 28 - SailNet Community
 1223Likes
post #271 of 1560 Old 12-01-2011
Allanbc's Avatar
I just did a "low bucks" project on my boat. I mostly used what I had on hand but did spend a dollar at Walmart. I went down to check on my boat and found that a Great Blue Heron has been hanging out on my transom. The evidence of his repeated visits was all over one side of my cockpit. It is common to see people hang things like plastic owls, CDs, monofilament line, etc around their boats but I wanted to build a better mousetrap.
I chose CDs as my bird deterrent. I used cheap CD-Rs that I had. I wanted them to really spin well to annoy the birds. I made a trip to Walmart and picked up a packet of barrel swivels from the fishing section. I then ran a light nylon cord from the back stays to the end of my mizzen boom. I ran a large nylon cable tie through the spindle hole and barrel swivel and left it loose around the CD. I then used a small nylon cable tie to attach to the nylon cord. In even the lightest breath of air, the CDs wiggle back and forth. In even a light breeze, the CDs spin wildly because of the swivel.
We'll see how this works.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Allanbc is offline
post #272 of 1560 Old 12-04-2011
Jnoiur Mebemr
StormBay's Avatar
Recently built a new table for our cockpit (and by built I mean drilled 6 holes, glued and Cetoled). The table is made from an old Purple-heart cutting board I bought a long time ago (from Marshalls) that was never really used as it would not fit in our sink when we needed to wash it. I also inset 2 cup holders, which I priced matched at $1.15 each from West Marine, down from there original outrageous $7.59. The mounts are original and the table can fold down and out of the way when not in use.
Steady Hand likes this.
Yu & Frank
StormBay is offline
post #273 of 1560 Old 12-06-2011 Thread Starter
bljones's Avatar
Storm, I like it!
It's 5 o'clock somewhere:
bljones is offline
post #274 of 1560 Old 12-06-2011 Thread Starter
bljones's Avatar
Okay, not strictly a boat project but...
boatshelves:
I'd rather build my Christmas gifts than go to the mall.
bljones is offline
post #275 of 1560 Old 12-06-2011
Nice, bl..... here's mine for the cost of a sheet of doorskin, and the set of lights... the rest is a recycled futon frame.
Faster is online now
post #276 of 1560 Old 12-07-2011
We just recently finished our floors in our Downeast 32'. The original teak & holly had rotted out and the subfloor was impossible to keep clean. Total cost was less than $50, and it looks pretty good if I do say so myself!
Full write up and photos are at MaineLiveaboards | Where Mainers living on their boats can connect.
Over40pirate likes this.
sep2x is offline
post #277 of 1560 Old 12-07-2011
Interesting choice of material. It will be interesting to see how well it holds up.
How thick was it, and is it interlocking or did it glue together?
The Following User Says Thank You to Faster For This Useful Post:
Celtic_Wind (09-24-2014)
post #278 of 1560 Old 12-07-2011
It was pretty thin, about 1/8th inch I'd say. Basically two pieces of vinyl stuck together, overlapping about an inch on each side with sticky stuff so they connect together. You can cut it really easily by scoring with a utility knife and snapping it, it breaks perfectly. We had some curves to cut which were more challenging but still a utility knife was all it took.
sep2x is offline
post #279 of 1560 Old 12-07-2011
Originally Posted by boatpoker View Post
A whole bunch of step by step photos of how I converted all my lights to LED's for $10.00 each
GREAT POST
This will be my winter project
BILL
ESPA
1969 MORGAN 30
wmmulvey is offline
post #280 of 1560 Old 12-08-2011
Glad I found Sailnet
Bene505's Avatar
Originally Posted by treilley View Post
We were always having problems with the springs that hold up the icebox lids. I converted to gas struts as a low cost solution.
Icebox Lid Strut
Tim,
We have currently 2 lids that have nothing to hold them up. It's a perfect opportunity for a low bucks project. The lids are very heavy.. How did you know what rating strut to use?
Here are pictures of our lids. (Sorry, one's not a very good picture.)
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
