Low buck projects- Let's see 'em! - Page 29 - SailNet Community
 1223Likes
post #281 of 1560 Old 12-08-2011
Tim R.'s Avatar
Originally Posted by Bene505 View Post
Tim,
We have currently 2 lids that have nothing to hold them up. It's a perfect opportunity for a low bucks project. The lids are very heavy.. How did you know what rating strut to use?
Regards,
Brad
Brad, the struts that Napa sells typically are designed to hold up very heavy hatches on cars. I purchased the lowest rated strut to try out and then exchange with the next higher one at Napa if necessary. I told this to the Napa guy and he said it would not be a problem. As it turns out, I picked the correct strut the first time and did not need to exchange them.
I had also done this with a previous boat(Pearson 28) to holdup the lazerette lids in the cockpit.
Sunday Driver likes this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #282 of 1560 Old 12-08-2011
Glad I found Sailnet
Bene505's Avatar
Thanks Tim.
With your quality workmanship, you deserve to strut around the marina anytime.
This is now high on my winter priority list.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #283 of 1560 Old 12-11-2011
No more curry buffets
Ritchard's Avatar
Inspired by you marvellous cheapskates, I undertook a low buck project, not the first, and certainly not the last, but I think this one is noteworthy.
Among the items needing renewing on my new-to-me '79 Endeavour 32 is a cutlass bearing. On the Eandeavour, the cutlass bearing (1-1/2 OD x 1" ID x 4 inch length) is carried in a bronze strut. Everyone told me that the way to do it was to remove the propshaft and sort of cut out the bearing from the strut. I have an (lazy) aversion to taking more stuff apart than necessary, so wasn't keen on the idea of removing the shaft. Then when I measured, I found that to take out the prop shaft, you have to drop my rudder. My response to that idea is "no freakin' way." I went looking for an option, and came up with this tool:
Strut-Pro Cutless Bearings
Now this Strutpro tool looks like an excellent tool set for a marina or maybe a club to have but a little rich for my single use. So I decided to make the tool. I drew up the bits, and sent them to my blacksmith buddy, but even when my buddy gives me a super deal, it was still going to be a little costly. Then I thought that I could maybe make the tool out of off-the-shelf parts. Here's what I came up with:
I know, it's a little unclear, but it's just plumbing parts, more or less. There are 4 1-1/2" pipe flanges, 2 step down Hex bushings (1-1/2 to 1-1/4", and 1-1/4" to 1" - it might be possible to find a 1-1/2' to 1" instead and save three bucks) there is also a 1" x 5" nipple fitting, with one end of the threads cut off. Fitting it all together is two chunks of 1/2" all thread, 6 nuts, 10 fender washers, and two 5/16" x 1" bolts with a couple of nuts and 4 washers holding together the "active" end. All 4 of the flanges have had two of their 4 holes drilled out to 1/2" to accept the rod.
Here it is laid out a bit:
Two of the flanges have been notched to fit over the shaft (forward of the strut) for the static side of the tool. The threaded bit of the flange nests perfectly on the end of the strut - though took a tiny bit of fiddling to get set properly.
The Active end of the tool has that piece of pipe nipple that slides over the propshaft perfectly, and is thick-walled enough that it engages the bronze part of the cutlass bearing.
To use, put the pair of notched flanges over the shaft above the forward end of the strut. Put the last inch or so of threaded rod through them, and bolt them up tight. Set the now paired set of notched flanges against the forward end of the strut, so that the threaded flange encircles the end of the strut. Slide the active end of the tool over the shaft from the rear end, and slide the free ends of the threaded rods though the paired flanges. Then slide the active end of the tool up tight to the cutlass bearing. Install three oiled washers, and the nuts. Snug up the nuts, double triple check that the static end is sitting correctly. If it is, start cranking on the nuts.
It took about 30 or 40 minutes start to finish to remove the bearing from the strut, much of that fiddling with getting the tool together and placed properly. A helper would have been very useful, but my teenaged sons would rather die. I oiled the active end washers and the threaded rod to help things along a bit. It might have been less difficult had I removed the set screws. They were so obscured by layers of paint, I didn't know they were there.
Once the bearing was out - that is, pushed out of the strut toward the bow, but still on the shaft - I slit it with a cutting wheel on a dremel tool. Which died.
Now I will get a new bearing, and use the same tool to force it back in.
If I were to make this tool again, I might go up one size in the threaded rod. I am not sure if the cheapskate design could be reworked for different sized shafts and bearings. I felt really lucky that both the pipe nipple, and the flanges, were perfect fits for my particular scenario.
Total cost for the tool? $50 more or less.
I am sure I have not been clear enough. Here is a video from Strutpro to show you what I have tried to emulate:
Faster, erps and Bob142 like this.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
The Following User Says Thank You to Ritchard For This Useful Post:
bristol299bob (05-21-2013)
post #284 of 1560 Old 12-11-2011 Thread Starter
bljones's Avatar
Ritchard, that's genius.
treiilley, great idea. If you wanted to make it even lower buck, hit up a junkyard and scavenge the parts used.
It's 5 o'clock somewhere:
bljones is offline
post #285 of 1560 Old 12-11-2011
Ritchard's Avatar
BL, not only cheaper, quite possibly better parts. These Home Depot Chinese pipe fittings are shockingly soft. You'd not really want to use them for something mission critical.
Edit to add: I thought BL was talking to me With respect to junkyard parts.
axel likes this.
Ritchard is offline
post #286 of 1560 Old 12-12-2011
Back to just the Jon boat
therapy23's Avatar
Ritchard,
That is really good.
Sorry it cost you a dremel too.
therapy23 is offline
post #287 of 1560 Old 12-12-2011
Broad Reachin'
kwaltersmi's Avatar
Several years ago I replaced a broken tiller handle on a Helms 25 with the handle from a wheel barrel. The oak wheel barrel handle was the perfect length and strength and also already had a nice hand grip section. You can see the details here.
Catalina 34
kwaltersmi is offline
post #288 of 1560 Old 12-12-2011
Ritchard's Avatar
Originally Posted by therapy23 View Post
Ritchard,
It was an off-brand that served for ten years. It owed me nothing.
Ritchard is offline
post #289 of 1560 Old 12-12-2011
The "perfect circle" cutter for a router, made from scrap 1/4" ply and a nail. Used it to install some deckplates this weekend.
The nail is banged through the plywood, measured from the outside of the router bit to the nail at a distance equaling the radius of the circle wanted. A small pilot hole is drilled in the center of the area to be cut, and the bit is either plunged or a larger hole is drilled on the periphery of the circle to be cut and the bit is plunged through that hole.
This is an old trick I'm sure, but makes perfect circles every time.
peterchech is offline
post #290 of 1560 Old 12-16-2011
$15 Anemometer
Sorry, no pics. I built a cheapie anemomenter for our previous boat. it consisted of 3 black plastic 1tbl measuring spoons ($3.00 at the dollar store), one black spray paint can lid (free), a bearing out of a dead VCR (Free), a little magnet that I had and a digital bike speedometer ($10).
Assembly consisted of cutting 3 slots into the paint can lid and gluing in the measuring spoons with hot melt glue. Next glue the magnet to the inside of the paint can lid, near the bottom and the bearing carefully glued into the center of the cap with lots of hot melt glue.
Next I mounted the whole thing on a shortened stantion which had a BBQ rail mount fitting at the bottom. (Both rescued from the trash at the club).
Tie wrap the bicycle spedometer sensor in place so that it picks up the magnet when it goes by.
To calibrate, I borrowed a friend's anemometer and my wife's hair dryer. Get the hair dryer wind speed reading from the anemometer and play with the wheel diameter on the bike speedo until you get the right wind speed.
Moutin a convenient spot on your boat. This worked great any my speedo had memory settings for max speed , average speed etc.
Matt
py26129 is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
