Low buck projects- Let's see 'em! - Page 34 - SailNet Community
 1223Likes
post #331 of 1560 Old 03-26-2012
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Re: Low buck projects- Let's see 'em!
STRF4-3528-W3-12V-WP-T | Electron.com
these have the 3528 smd led's with a lower lumen output 180 -200 /m
power draw is 4.8 w/m
efficiency is 0.024 to 0.026 watts / lumen
STRF5-5050-W3-12V-WP-T | Electron.com
these have the 5050 smd led's with a higher lumen output 200-230 /m
power draw is 7.2 w/m
efficiency is 0.031 to 0.036 watts / lumen
it looks like the 3528 puts more energy into light and thereby less into heat
the biggest issue is regulated 12v supply over voltage may damage the unit
for switching a small latching push button would be easy (push once for on again for off)
for waterproofing circuits I use something called Dragon Skin FX pro 2 part silicone (generally used for casting makeup appliances) non-conductive and works great. Good for ip67 rating if you encapsulate your components and prep your surface
William White
SV Rangatira
1974 Discovery 32
Bill-Rangatira is offline
post #332 of 1560 Old 03-27-2012
Closet Powerboater
MedSailor's Avatar
William White
SV Rangatira
1974 Discovery 32
Whoa! Wait! What? You can IPX-67 something yourself with this stuff? You must show us how! Details/photos please!!!
MedSailor
MedSailor is offline
post #333 of 1560 Old 03-27-2012
Bill SV Rangatira
not my idea found it on a web site for water cooled pc's I'll see if I can find the link
post #334 of 1560 Old 03-27-2012
Bill SV Rangatira
post #335 of 1560 Old 03-27-2012
No more curry buffets
Ritchard's Avatar
I enjoyed this thread so much the first time, I just read through it again.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #336 of 1560 Old 04-09-2012
Hi All,
Great thread; some great ideas! Anyone have a low-buck method to replacing the hatch lenses? Mine are getting badly checked, and in need of replacement, and I was quoted $400.00 per hatch to have them fixed!!
Thanks...Jeff
eddi887 is offline
post #337 of 1560 Old 04-09-2012
jsaronson's Avatar
Try
Select Plastics, LLC - Connecticut's Best Custom Fabricated Plastics and Marine Hatch Repair
Not sure what they charge, but they seem to specialize.
jsaronson is offline
post #338 of 1560 Old 04-09-2012
Originally Posted by eddi887 View Post
Hi All,
Thanks...Jeff
That sounds like a quote from Select plastics.. they will do a good job and if your frames are sound that may well be the best way to go. These things are expensive new!
It is possible, however, to replace the lenses with Acrylic yourself and if your seals are still good that may be an option. Check Mainesails' Compass Marine site - he may have some tips. The sealant/adhesive Dow Corning 795 comes highly recommended for such jobs.
Faster is offline
post #339 of 1560 Old 04-09-2012
Administrator
administrator's Avatar
here's a low budget project....
administrator is offline
post #340 of 1560 Old 04-09-2012
Senior Moment Member
SloopJonB's Avatar
If you can use a router table or a jigsaw and a drill you can do it yourself, as Faster suggests. I did one for $100. Get a piece of plexi - an offcut will often suffice and is cheaper than having them cut a full sheet.
Dow 795 is the sealant of choice - it's what they use to hold the glass in office towers so it should hold a couple of square feet of plexi.
It's an easy job - cleaning the old sealant off the hatch is the slowest part - the mounting lip must be PERFECTLY clean.
SloopJonB is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
