Like Tree284Likes
  #361
Old 06-05-2012
mitiempo's Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by montenido View Post
Okay, here is another one that you all might like. To create air space beneath my vee berth cushions I bought a PVC lattice panel at Home Depot. Cost was about $28 because I got the one that has 2" openings, not 4". Anyway, it is 4'x8' and I cut it to fit, and then cut it into smaller pieces so that I could access different compartments underneath without lifting the entire lattice. This should allow plenty of air under the cushions and cut down on dampness.
Here are a couple of photos. Let me know if you like it.
Cheers, Bill
The key to eliminating dampness is air circulation. Any commercial product for this allows air to circulate throughout the under cushion area. Those open areas in the lattice look like they are all isolated from each other.
cghubbell and SloopJonB like this.
Brian
  #362
Old 06-06-2012
hriehl1 is on a distinguished road
To our Administrators:
Is there any way to extract this entire thread, WITH photos, into a PDF file? There's lots of good stuff in here but the multi-page (and growing) format is not easy to wade through.
  #363
Old 06-06-2012
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Personally, I don't mind wading into this stuff. Agree, there is a ton of good stuff in here.
Bristol 27
Cirque
  #364
Old 06-06-2012
2weelz4me is on a distinguished road
Originally Posted by bljones View Post
In this forum, we've seen big projects on small boats and small projects on big boats- let's see the cheap projects! Show us what you have done on your boat on a budget.
Here's the rules:
1) Gotta be under $100 US, or equivalent currency.
2) You must have done it yourself. Although, if you found someone to work on your boat for less than $100, feel free to post contact info.
3) bonus points will be given for elegance and ingenuity.
Here's one of mine:
I needed a cockpit table. Well, I, personally, didn't need a cockpit table, but the admiral did, and I need a warm place to sleep, so you can see how the stars aligned on this one. I sussed out commercially available, marine priced cockpit tables and promptly gagged. So, I thought to myself, "self, you could make it yourself for a lot less." One problem. Well, four actually. I have limited woodworking skills, limited woodworking tools, and limited time. oh yeah, and I am cheap.
So, I went to plan "c".
I spent some time eyeballing the cockpit in question:
Then I moseyed into action. I bought one of these for $29.99
A frenzy of measuring, remeasuring, cutting, screwing, drinking, varnishing, etc. later, and this is how it finished up:
Let's see yours.
That is an awesome job! Don't think we didn't notice the refinished wood on the compass too. I for one think you did a great job.
  #365
Old 06-06-2012
Re: De-junkerator
Originally Posted by Barquito View Post
$100 of paint and sandpaper. DIY baby!
wow, what a difference.
  #366
Old 06-06-2012
Jetexas's Avatar
Jetexas is on a distinguished road
I think this counts as a low-buck project. I needed to replace all my old, crazed leaking ports. Beckson wanted $610 + tax + shipping for the four windows. I bought new acrylic, some 3M mounting tape, and some Dow Corning 791 and made some new ones myself for $160.
Three warnings:
1) Give yourself plenty of time. It took me almost four hours per window (although each one did go faster than the last as I got better at scraping the old silicone off, cutting the acrylic, etc.)
2) Make sure you buy enough acrylic to make one or two more ports than you need because I did have one shatter as I was cutting it out.
3) Make sure you order the black Dow Corning 791. I didn't realize it came in multiple colors until I was ready to seal my ports, and then it was too late to send it back and wait to order more.
Here's more details on my blog: http://www.fredfacker.blogspot.com/2...arwind-27.html
texwards likes this.
  #367
Old 06-06-2012
montenido's Avatar
montenido is on a distinguished road
Alas, Mitiempo, you are correct about the air circulation under the cushions.
Stand by for modifications
Cheers, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
  #368
Old 06-06-2012
Ritchard's Avatar
No more curry buffets
Ritchard is on a distinguished road
Three warnings:
Here's more details on my blog: Live While Alive: Replacing fixed ports on a Starwind 27 sailboat
This was a nice job. How did you handle interior trim?
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
  #369
Old 06-06-2012
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
I like my coffee in a mug and have broken three of them when they fell off the binnacle drink holder. So, a scrap piece of "plastic lumber" and some time on the lathe - voila:
empty
Turned over showing how it fits in drink holder.
Rik
mitiempo likes this.
Irwin Citation 34
  #370
Old 06-10-2012
erps's Avatar
the pointy end is the bow
My solar panels are mounted on stainless tubing between two stanchion posts. When I tipped them up, I've been hanging them up with a line tied to my bimini frame, but I wanted to support the outside edge with a pole. The easiest thing to do was to attach a bimini pole end receiver on to my toe rail, but my toe rail is teak with a curved top and I didn't want to have to cut a flat groove in the top of the toe rail and I figured the metal piece would be a toe stubber and a knuckle buster.
So I whittled down a UHMW block with my table saw and router to make a pole receiver on the toe rail and then used a collapsible piece of stainless tubing to pole out my solar panels at a 45 deg angle and horizontal. I got the tubing and the tubing ends used for a good price, $14. The UHMW was some stuff I had in the garage for another project. So far so good.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
thegreatescape1
You may post attachments
You may edit your posts
LEDs afloat GoodOldBoat Good Old Boat 27 03-21-2013 08:07 AM
Low buck bow thruster?? wildcard Gear & Maintenance 23 01-11-2009 08:57 AM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
SEO by vBSEO 3.6.1
