Low buck projects- Let's see 'em! - Page 44 - SailNet Community
 1223Likes
post #431 of 1560 Old 08-31-2012
Extra Storage Space
In need for a compact extra storage space.
A 24 pocket hanging shoe bag hanging on the head door.
BED, BATH & BEYOND
$14 AND CHANGE minus a 20% discount coupon
$11 AND CHANGE total cost
Razcar likes this.
wmmulvey is offline
post #432 of 1560 Old 09-04-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Low buck projects- Let's see 'em!
Console for stereo, VHF, and one speaker:
It fits where the stove should be and adds some counter space (also holds my butane burner).
I already had the electronics; I made the console from scrap plywood I had hanging around plus a small piece of furniture grade stuff for the lid (also hanging around). The only expense was some hardware and spray paint (about $3).
This is just a working mockup so I would have something for the stereo and VHF without drilling holes (that I'll likely change my mind about later). The final version will not have the speaker; the stereo & VHF will be lower and side by side. This will lower the burner; it's a little too close to the shelf behind the unit. I'll also add a fiddle to the edge of the lid and some cleats to hold the burner in place.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #433 of 1560 Old 09-04-2012
Originally Posted by PorFin View Post
Like our dear friend bl, I've used the West pumps through gallons of resins, and I've never been disappointed with the mix. But those pumps aren't cheap (make that inexpensive) and that always rubbed me a little against the grain.
Fast forward a couple of projects. I had numerous spots that needed the strength of epoxy but not the volume even one pump of the West pumps delivered. I wound up using some MAS epoxy, which has a 2:1 mix ratio. Looking for the convenience of the metered pump (but without the cost) I raided our recycling bin and pulled out a couple of Dial liquid hand soap dispensers. I cleaned them up and grabbed our digital kitchen scale. I did some consistency checks using water as the medium, comparing the weight of single and multiple strokes of both pumps. Guess what? They were pretty much dead on. So, after charging them with the MAS resin and hardener, I now have a "metered" pump set for small batches of epoxy.
I also used to have to make small batches of epoxy and HATED wasting a full stroke of each. I switched to MAS and bought a bunch of 50 ml mixing cups from Jamestown Distributors. A trip to the grocery store to buy a set of ketchup and mustard squeeze bottles for about $4... (do you see where this is going?) and voila! I squirt out 10 or 15 ml of resin, and half as much hardener to bring it up to 15 or 22.5 ml and there you go!
Added benefit is I can store the epoxy some place cool and keep the squirt bottles in my shop to fill up when necessary.
CS 36M DIANTHUS
sailordave is offline
post #434 of 1560 Old 09-04-2012
Senior Moment Member
SloopJonB's Avatar
I'm currently using a 4-1 ratio epoxy and I use the same graduated cup system. I have to admit I prefer 2-1 or 1-1 ratios but the cups make accuracy simple with any ratio.
SloopJonB is offline
post #435 of 1560 Old 09-05-2012
Pirate Chief
both the table and the netting I will be doing this wekend
Paddyd is offline
post #436 of 1560 Old 09-05-2012 Thread Starter
bljones's Avatar
excellent!
pics, man, we need pics!!
It's 5 o'clock somewhere:
bljones is offline
post #437 of 1560 Old 09-05-2012 Thread Starter
bljones's Avatar
Hey, hey,this is the low-buck thread- there ain't no "working mock-ups" if it's working, it aint no mock-up- it's done. if it AIN'T working...it's a "pre-production prototype."
All kidding aside, it looks slick. but don't get rid of the functionality of the galley stove.
bljones is offline
post #438 of 1560 Old 09-08-2012
2nd mate
As for cushioning on the cockpit railings, i figured this out:
It's pipeline insulation for houses (smallest size) at 75 Eurocent/meter covered in black ducktape.
I copied this idea from a competition sailboat I saw once.
bartvdv is offline
post #439 of 1560 Old 09-08-2012
When we did ours we slid a piece of plastic pipe inside the insulation.. you'll find the wire will cut through the foam in relatively short order wherever you lean on it. We also covered the works with a Sunbrella sleeve to match the canvas.
Steady Hand likes this.
Faster is online now
post #440 of 1560 Old 09-08-2012
Those look like fairly beefy lifelines . . .
mikel1 is online now
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 02:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 05:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 08:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
