Like Tree284Likes
  #481
Old 11-15-2012
miatapaul is on a distinguished road
Re: Low buck projects- Let's see 'em!
Originally Posted by BubbleheadMd View Post
I have one of those crappy, red lanterns. The Deitz looks a far sight better.
I have two Weems and Plath yacht lanterns (Don't judge me, they came with the boat!) and I use them regularly.
My understanding is that the "old" Weems and Plath lanterns work well, but the new ones are really for decoration and do not work as well, and frequently leak.
I had a couple of the cheap red lanterns from Big Lots that lasted a few years, paid 4.99 for them. Worked for my purposes, but would not want to try to read by the light. They were nice on the porch, and did not attract insects.
Don't worry I think we have already "judged" you!
  #482
Old 11-15-2012
white74's Avatar
white74 is on a distinguished road
Originally Posted by bljones View Post
Sloopy, it depends on the wall thickness of the pipe used, as well as the thickness of the cross section, but on foams I'd use store bought clamps.
to add more pressure you could slip a section of inner tube over the clamp
  #483
Old 11-23-2012
Bob142 is on a distinguished road
Sorry Sumner10 long delay...
I can't help with the name or manufacturer of the lights ... They came with the boat so I think 1972 ... All they have is the voltage and made in Japan...
Originally Posted by Bob142
Sumner 10
Try this link instead...got to find a better way to post pics...
https://www.dropbox.com/sh/8zuketlwx6tjc4f/sQnpDk5fZp?m
That worked great. I really like the looks of the light....
...What are the fixtures you are using? Thanks,
Sum
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
  #484
Old 11-25-2012
willyd's Avatar
美國佬
willyd is on a distinguished road
My boat came with a heavy-duty Garelick Eez-in outboard motor bracket that was mounted to a custom-made wooden base on the transom. Unfortunately, the Garelick bracket didn't put any of the long-shaft outboards I tried low enough in the water, and couldn't be adjusted further. I sold the Garelick and devised this mount from two aluminum L-shaped pieces and two square sheets, a surplus wooden bracket, and some stainless bolts and screws. I had to cut the inner edge of the square aluminum pieces at an angle so that the motor sat lower in the water.
1964 Whitby 25
Severna Park, Maryland
  #485
Old 11-29-2012
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Emergency tiller!
I prefer a tiller. My I-28 has a wheel. It also has (had and still has) its original tiller. Mr. Perry designed a very well balanced boat. I replaced the wooden tiller with a short section of aluminum pipe and now have a tiller, too! It stands vertical over the rudder post and spins out of the way when not in use. After I have cleared the lobster pot danger zone I can relax and steer with one finger. It will allow me to add a Raymarine ST2000. I want to play with John Letcher's Self-Steering for Sailing Craft ideas, too.
Free! It was a piece of scrap I scrounged.
Down
  #486
Old 11-29-2012
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
Looks good. What is the fitting you are using to connect the rod to the stanchion post cap?
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
  #487
Old 11-29-2012
Tundra Down
It is the original tiller's fitting. I just removed the wooden tiller and bolted on the piece of pipe. It took two measured taps with a 4 pound hammer to flatten it where necessary. The wooden tiller is resting in the shed.
The wheel was an "upgrade" by a po. Thankfully the original tiller stayed with the boat.
Down
  #488
Old 11-29-2012
Brewgyver's Avatar
Brewgyver is on a distinguished road
Downeast, I'm a tillerman, too (Tea, anybody? ) Just had to ask what that huge lever just forward of the wheen is? Turn signal stalk?
Oh, and nice clean job, too.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
  #489
Old 11-29-2012
Tundra Down
Thanks,
The huge one to port is the shift lever for the A-4. The end of the throttle lever is just visible to starboard. Reverse with an A-4 is held in place while using. You yank up on her and hold.
Down
  #490
Old 11-29-2012
RobGallagher's Avatar
HANUMAN
RobGallagher is on a distinguished road
Hmmmm... using your emergency till for an auto pilot.... hmmmm.... anyone else done this?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rhr1956
You may post attachments
You may edit your posts
LEDs afloat GoodOldBoat Good Old Boat 27 03-21-2013 08:07 AM
Low buck bow thruster?? wildcard Gear & Maintenance 23 01-11-2009 08:57 AM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
SEO by vBSEO 3.6.1
