Like Tree285Likes
  #491
Old 11-29-2012
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Re: Low buck projects- Let's see 'em!
My "emergency tiller" Is the boats tiller with a shortened arm that is now a piece of aluminum. Instead of storing the "emergency tiller" somewhere below, it lives, out of the way on the rudder post. I can mount the tiller pilot to this tiller just the same way I would if I didn't have a wheel. The boat is very well balanced and the leverage will be more than adequate.
Much simpler than installing one on the wheel. Less expensive, too.
Down
  #492
Old 11-29-2012
Brewgyver's Avatar
Brewgyver is on a distinguished road
Originally Posted by downeast450 View Post
Thanks,
The huge one to port is the shift lever for the A-4. The end of the throttle lever is just visible to starboard. Reverse with an A-4 is held in place while using. You yank up on her and hold.
Down
I should have guessed that, I have an A4, too, levers on port side of cockpit, back and hold for reverse.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
  #493
Old 12-04-2012
richardb123 is on a distinguished road
No pic yet, but two of my boats steered wonderfully with a shet to tiller system made from surgical hose. Cost almost nothing. Steered for hundreds of coastal miles.
  #494
Old 12-08-2012
Tundra Down
Richard,
I am looking forward to "playing" with it. Our summer sailing conditions here will compliment it well. Playing with the wind is what we are doing, right? Getting it to take care of the helm will be fun!
If you have pictures you can share that would be great. "The Man", John Letcher, is a neighbor here on Mount Desert Island. I don't plan to bother him but he is a wonderful resource if I need it. It looks straight forward enough for my limited abilities.
Down
  #495
Old 12-08-2012
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
I've been looking for a new tool box in the last 10 or so countries.
Mine is ok but too small, and has a great concertina top for old nuts and bolts etc.
It lives under the Nav seat so there's a bit of room but not for a bigger box.
Also wanted to separate the spanners (wrenches) from the junk and can never find a flicking screwdriver, let alone the one that I want!
Did a few HOURS in Home Depot (like Bunnings in Australia) and nothing suited.
But they did have a BUCKET bag that turns a bucket into a tool bag... Which I don't want....
But at $7.20 incl tax there was promise!
Separated and laid out
Cut into four parts.
Rolled up they fit in the Nav seat with the tool box.
And I still have one piece left over.... Goody I can buy more tools!
Sea Life
Notes on a Circumnavigation:
I write with an iPad and its spell checker changes some words. Beware.
  #496
Old 12-08-2012
MastUndSchotbruch is on a distinguished road
Re: Low buck "Solar Panel"
Originally Posted by sevseasail View Post
I have very basic electrical needs; I have one group 31 battery that I use to run the stereo, keep cellphones charged and run navigational lights when needed.
Me, being the way I am, don't like to leave the power cord connected to charge the batteries while I'm not there (I'm afraid to come back to a charred piece of fiberglass on the bottom of my slip) so, when I go sailing I don't spend too much time in the slip, therefore, I never get enough charge to sustain the battery. The solution: solar panel.
I looked for something small that I would not need a controller (keep it simple) and found a 5watt panel at Harbor Freight for $39.00 (great deal compared to a similar 5 watt panel at WM for $69.00) I actually like the aluminum construction of the frame a lot better than the plastic one at WM.
Then I considered the best place to mount it on the boat and came up with the stern pulpit, the only challenge was to come up with some sort of bracket or something to hold it in place, I dug through my garage scraps and found an aluminum "L" section that was perfect for the job, a couple of "U" bolts, nuts and washers from the store and some fabricating....
Here it is mounted to a pipe in my garage
Here's a closeup of the mounting bracket
Here it is on the boat
Another one
I installed it last Friday when the battery was showing 90% charge, came back on Sunday for a sail and the battery showed 100% charge, so, I'm pleased with the results.
I forgot the cable ties, so I still have to finish the installation.
Panel cost: $ 42.00
Miscellaneous nuts, washers and bolts: $ 5.00
Aluminum L bracket (garage scrap) $ 0.00
Not having to worry about charging the battery " Priceless"
I believe I bought the same panel some time ago, don't even remember for what project. But when I looked at the specs, I don't think it was rated for outdoor settings. Is yours?
  #497
Old 12-08-2012
Ritchard's Avatar
No more curry buffets
Ritchard is on a distinguished road
What good would an indoor solar panel do you?
SloopJonB and ODay e-pod like this.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
  #498
Old 12-08-2012
To give you a fake tan!
Sea Life
  #499
Old 12-10-2012
Tundra Down
Dash replacement.
I added a tach and had to mount it in the dash. A scrap of marine plywood, some epoxy fairing putty and a coat of epoxy paint and now TD has rpms to watch from the helm.
The old
The process
The product
Cost? The tach cost a few bucks so it isn't part of the low buck project. The dash was from stuff in my shop.
I have asked Santa for an inexpensive automotive backup video camera ($30.00) that I plan to flush mount at the base of TD's pedestal facing the dash. My Garmin chart plotter has a video input I am not currently using. It would be nice to have the chart plotter's display include my A-4's instruments. It is worth a try. I will report back!
Down
  #500
Old 12-15-2012
This is a question you may want to ask Harborfreight. The instruction manual contains a warning "Do only use in dry environments."
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
coultereng , gdt35
You may post attachments
You may edit your posts
LEDs afloat GoodOldBoat Good Old Boat 27 03-21-2013 08:07 AM
Low buck bow thruster?? wildcard Gear & Maintenance 23 01-11-2009 08:57 AM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
SEO by vBSEO 3.6.1
