Low buck projects- Let's see 'em! - Page 62 - SailNet Community
 1223Likes
post #611 of 1560 Old 04-28-2013
fryewe's Avatar
Re: Low buck projects- Let's see 'em!
Fuel tank level system:
I am old school when it comes to tank level indication having lived with failed electrical/electronic indication that required draining tank after tank to repair frequent failures and then refilling and recalibrating the instruments. I know the new electronic instruments are much more reliable but my engine burns less than a quart an hour and there is no need to know fuel level on an instantaneous basis. The tank is under the engine and if I did have an electronic instrument it would likely be a PITA to access and repair or replace.
So when I replaced the fuel tank on Talofa Lee I planned for manual tank measurement. The tank is under the engine and the dipstick method of checking requires that the stick be flexible. I have always used a 1/4 inch dowel. However last time I used the dowel it cracked. By good fortune the bottom piece didn't fall into the tank.
This week my wife waved a broken chain-type dog leash at me and asked if I could use it (I am always stashing this and that item that is broken that I may "need" at some point in the future so she frequently checks with me before throwing things out.) She didn't know it but she was waving my low cost foolproof fuel tank level indicating system at me.
That chain is the perfect tool for measuring the tank level. It is flexible. It is heavy so it hangs directly down into the tank. All I needed was something to keep the upper end from falling into the tank and to calibrate it.
The tank was still empty so I filled it with five gallon jerry cans and calibrated the chain at five gallon increments (25 gallons total). I marked the chain at each five gallons and marked the point where the chain meets the top of the fill tube when the first link hits the bottom. I put a plastic cable clamp through the top link to prevent dropping the chain into the tank. I marked the chain increments with tightly wrapped red rescue tape that I had in my tool box.
Here it is:
I used about eight inches of rescue tape which is about a dollar a foot. The clamp was one of a pack of several different sizes I bought at a big box store a few years ago...perhaps another buck.
I am sure I will be happy with the TLI's accuracy and reliability.
bljones and Rhapsody-NS27 like this.
fryewe is online now
post #612 of 1560 Old 04-28-2013
Originally Posted by Rhapsody-NS27 View Post
I didn't know about this. Thanks.
I'll remember this when I move East.
People move East?
Really?
xymotic likes this.
ccriders is offline
post #613 of 1560 Old 04-28-2013
Old enough to know better
Originally Posted by MastUndSchotbruch View Post
Don't know what part of the world you are posting from but the automated radio check on Channel 27, sponsored by Sea Tow, is FAR superior to your method. See http://www.seatow.com/boating-safety...d-radio-checks
Where I am (Upper Chessie), they have at least two stations (Annapolis and Great Oaks Landing) that my 20 year old basic VHF reaches.
OK, OK, I admit it is a stretch to call this a 'project' but it is definitely 'low bucks' (free!). I hope pointing out this service out helps someone. If nothing else, it might reduce the stupid radio checks on Ch16 followed by the inevitable admonishments by USCG.
[Note added in proof: Sorry, I have no idea why sailnet mangles the URL. It looks fine when I submit it and I tried to fix it but SN does its mangling. Just google it...]
I was thinking "hey honey go out in the dingy. Keep rowing I want to test the range. Yes, I know your tired, but I have almost finished my beer, I mean Your not quite far enough.... Let me sail the other way for a while and get a real good test of the range."
Of course this could be part of the reason I am getting divorced!
miatapaul is offline
post #614 of 1560 Old 04-29-2013
Asleep at the wheel
jimgo's Avatar
Paul, I thought you were going to say that you sent her out to the bow, then asked her to face forward to see if the radio worked. Now turn back and face me; yup, still works. One more step backward? (splash)
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #615 of 1560 Old 04-29-2013
that was the first wife...
slax is offline
post #616 of 1560 Old 04-29-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Originally Posted by ccriders View Post
People move East?
Really?
When I am finally free of the military and get out of Tennessee, I'm looking at moving to VA and maybe have my boat in MD. I'm looking at Marinas between Annapolis and Solomons. Still have a few years before that happens.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #617 of 1560 Old 04-29-2013
Can't argue with that. Sailing the Chessapeake is fabulous, just about everything you could want in a home cruising ground.
John
ccriders is offline
post #618 of 1560 Old 04-29-2013
One of None
deniseO30's Avatar
Gmimbled force 10 PITA
After way way too many hours of wondering what to do to enclose around my F10 range and after 3 attempts this is the end result.
Long box behind the stove with one long side angled so the stove can swing past it. The lid for the box will be cutting board. On the sides it's plywood with white Formica glued on and then screwed with finish washers to make them easy to remove for stove servicing.
swing up;
swing down;
sitting level with lid off box. (still needs hold downs of some sort)
There is a cutting board for the stove top but I'll make a really nice one someday.
cost less then $25 since it was scrap plywood, Formica
Bene505 and bljones like this.
My last project!
deniseO30 is offline
post #619 of 1560 Old 04-29-2013
Tundra Down
downeast450's Avatar
That is only half way East!
Down
ccriders likes this.
Islander-28, Marshall Sandpiper
downeast450 is offline
post #620 of 1560 Old 04-30-2013
rhr1956's Avatar
Making new circuit breaker panel box. Adding a couple 12v accessory plugs, a LED power indicator light and a analog battery voltage meter. Got some 1/2" oak at Lowes for about $20, indicator light at Frys for $3, voltage meter for $9. I already had some stain and varnish. A couple small brass hinges and an inside cabinet latch for another $6. Another $20 worth of Becks. So let's see...about $58 total. That should qualify for low bucks. I'll post a pretty picture after it's on the wall. Sorry for the junky picture.
downeast450 likes this.
rhr1956 is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
