Low buck projects- Let's see 'em! - Page 63 - SailNet Community
 1223Likes
post #621 of 1560 Old 05-01-2013
Tundra Down
downeast450's Avatar
Re: Low buck projects- Let's see 'em!
rhr,
Please show a couple of pics of the finished product. Looks good!
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #622 of 1560 Old 05-01-2013
midlife crisis member
AllThumbs's Avatar
I bought this LED flashlight at the dollar store for $3.00
Here is the circuit board inside:
I cut it into two sets of 9 and a set of 6:
It took 5 minutes to modify the circuit to optimize it for 12 V:
Test it out. Perfect:
The original fixture is forty years old, and the guts were all corroded. The reason for the project. I glued the circuit board into the old fixture with some silicone:
Beauty. Excuse the rain:
It draws 45 mA. The original 6W bulb draws 500 mA. It's now brighter, although the LEDs are somewhat uni directional. The original lens diffuses the light enough that it is easily seen from any forward angle. I did both sides. I might use the 6 LED section for the stern light.
AllThumbs is offline
post #623 of 1560 Old 05-01-2013
Asleep at the wheel
jimgo's Avatar
Did you put the resistor and jumper in there? What value resistor did you use?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #624 of 1560 Old 05-01-2013
AllThumbs's Avatar
Yes. I used 68 ohms. I also had to file away the traces on the circuit board in 4 places. This value resistor was calculated based on the voltage drop of the LED's and the current of the LED's. I would be happy to explain how that value is calculated if there is interest.
post #625 of 1560 Old 05-01-2013
OPossumTX's Avatar
Originally Posted by MedSailor View Post
Wireless night vision camera with it's own Wi-fi on a turret for $35??!! Wow, the electronics world never ceases to amaze me.
5 years ago, for $35 you could chose one of the above items for that price.
Anyone know of small stand alone LCD screens that could combine with one of these puppies (without the need for a computer) for an engine room camera?
Medsailor
If an engine room camera and remote monitor is what you want, I would think one of the "backup cameras" you can find on line for much less than $100 would do the trick. It is all 12 VDC with no need for any converters.
Check this one out: http://www.amazon.com/Digital-Monitor-Waterproof-Camera-combo/dp/B005C76ZXC/ref=sr_1_15?s=automotive&ie=UTF8&qid=1367454634&sr=1-15&keywords=backup+camera
The trick would be finding one with a weather resistant monitor. All of them have weather resistant cameras but the monitor is intended to be mounted inside the car/truck.
OPossumTX is offline
post #626 of 1560 Old 05-01-2013
bristol299bob's Avatar
thumbs, do tell.
btw looks great!
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #627 of 1560 Old 05-01-2013 Thread Starter
bljones's Avatar
As usual, nice work AT. you back on the Dock this season?
It's 5 o'clock somewhere:
bljones is offline
post #628 of 1560 Old 05-02-2013
AllThumbs's Avatar
After School was launched yesterday. Slip 6-51 buddy. Pretty lonely on the dock so far.
post #629 of 1560 Old 05-02-2013
4KSB driver.
SHNOOL's Avatar
Dock bumpers... Cost $27 total for 3.
90 degree brackets... 2x4, noodle float (replaceable) and outdoor carpet...
Ok, there are no cleats on TOP of our docks, only rings on the vertical of the fingers. My boat fits tightly in the slip (there is 9 feet between fingers boat is 9'2" wide at the deck). With large fenders, they rubbed harshly against the dock, I needed something wider, and thinner that was removable. My wife came up with this idea, and I think it was pretty genius.
$24 for a 5'x26" piece of outdoor carpet backed with rubber.
$2 for 2 noodles.
I had the 2x4s.
There are (2) 5' ones for port/starboard, and I created one that is 4' wide for the bow.
Bene505, katsailor and YachtOgler like this.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #630 of 1560 Old 05-02-2013
TakeFive's Avatar
It is generally not advisable to put white LEDs into nav light fixtures that were designed for incandescent lights. LEDs emit light over a very narrow range of wavelengths, and when put through traditional incandescent color filters the color fails to meet USCG requirements because. For instance, the green nav light on the starboard side of your boat tends to be blue colored.
I'd suggest checking this out carefully before you all get too excited about this mod.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
