Low buck projects- Let's see 'em! - Page 68 - SailNet Community
 1230Likes
post #671 of 1562 Old 05-14-2013
Tim R.'s Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by jimgo View Post
Tim,
Another idea is to use pool noodles. Our dollar store had them. They are a bit thicker, and more comfortable than the pipe insulation (I did the pipe insulation on my old boat).
Definitely a great low buck solution Jim but that would not pass the sniff test by the admiral. Had to be matching Sunbrella and that is where the expense lies. I also wanted to balance the visual obstruction and comfort factors.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #672 of 1562 Old 05-14-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Covering the hull liner in the Vee was simple as hooking the interlocks together on that gray foam floor matting. On sale at HF @ 4/7.something. I stowed them there before trying to put 'em on the floor and it worked so well, I'm leaving them ! The sole will get sumpin' else.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #673 of 1562 Old 05-14-2013
The foam stuff for hull liner, huh? That actually sounds interesting. Some insulation from sound and temperature and probably doesn't look too bad.
Pics?
tschmidty is offline
post #674 of 1562 Old 05-14-2013
Asleep at the wheel
jimgo's Avatar
Tim,
I was suggesting wrapping the noodles in Sunbrella, rather than the pipe insulation. It would still match.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #675 of 1562 Old 05-14-2013
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
I am in the process of wrapping large (3" dia) foam noodles with Sunbrella for my dinghy rub rail. I am using contact cement to attach the fabric to the noodles. I slit the noodles lengthwise and used spacers to hold the edges apart while I applied contact cement to one cut edge and the rest of the noodle as well as the fabric. When the cement is ready, I attach one edge of the fabric inside the slit (the cut edge that has the cement on it) and wrap the Sunbrella tightly around the noodle. The bond is instant. After wrapping around the noodle I cut the fabric, overlapping the slit by about an inch. Then I apply contact cement to the other cut edge in the noodle and tuck the remaining fabric in. This sounds complicated but its not. The point is to completely wrap the noodle with Sunbrella with the ends tucked into the slit but without gluing the slit shut. When finished, the noodles will snap over the gunnels of my El Toro dinghy and serve as a continuous fender to protect the mother ship.
I'll post pictures when I'm done.
Henry
Chiquita
Steady Hand likes this.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
post #676 of 1562 Old 05-19-2013
Tundra Down
downeast450's Avatar
The Kelly Kettle is great!
Cooking on shore can have limits when open fires are restricted. We use a Kelly Kettle to boil water and heat a pot of "whatever". It is a double walled aluminum kettle. There is a "pot rack" that sits on the chimney to heat an additional pot. Fuel is small sticks. It is even self regulating because when the water boils it spills into the fire "box" reducing the heat. When we want to boil a liter of water for 40 minutes it is perfect. We use it to "prepare" freeze dried meals. The pot rack allows us to heat anything from a coffee pot to a frying pan. NO OPEN FIRE!
Some photographs here!
http://s598.photobucket.com/user/gfa...Kelly%20Kettle
Down
Blue Eagle likes this.
Islander-28, Marshall Sandpiper
downeast450 is offline
post #677 of 1562 Old 05-22-2013
One of None
deniseO30's Avatar
Made a serving tray that will fit on the stove top, I may cut the handles off if they restrict reaching over to the ice box on the boat. Not finished dovetail keys for the corners, sanded or varnished yet. Made from free wood! Like my dining room? engineered maple floor, real cherry for the trim, baseboards and pass through has a real cherry counter top...
My last project!
deniseO30 is offline
The Following 2 Users Say Thank You to deniseO30 For This Useful Post:
MMR (05-22-2013), SloopJonB (05-22-2013)
post #678 of 1562 Old 05-22-2013
Tim R.'s Avatar
Tim,
Gotcha. When I read your post I visualized the bare noodles as I have seen these bare on some boats before. I wanted to keep the obstruction to a minimum. I have built these for previous boats so I knew what worked for us.
Coming down to your neck of the woods next week for a wedding in Lancaster.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #679 of 1562 Old 05-22-2013
Senior Moment Member
SloopJonB's Avatar
Henry
Chiquita
Gluing the fabric down is a great idea - saves all that sewing (which I can't do anyway!)
Just out of curiosity, why did you go to all the trouble of slitting noodles instead of simply using pipe insulation?
Also, how did you rig things up to get a straight cut from end to end? I've always found cutting any kind of tubing without having the cut wind around the tube a bit is very difficult without some sort of jig.
SloopJonB is offline
post #680 of 1562 Old 05-22-2013
Cruiser2B's Avatar
Well. I needed a new holding tank, one was stinkin and only 6 gallons, decided to take advantange of available space so I made one. New one holds 14 gallons and still fits in same location as old one
All said and done I had about $110.00 including hose, fittings and materials.
I posted quite a few pics on my blog, here is the link....i hate resizing pics
http://svsalacia.blogspot.com/2013/05/crap.html.
so far it holds water just fine
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
The Following User Says Thank You to Cruiser2B For This Useful Post:
MedSailor (05-24-2013)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
