Low buck projects- Let's see 'em! - Page 69 - SailNet Community
 1230Likes
post #681 of 1562 Old 05-22-2013
Jnoiur Mebemr
StormBay's Avatar
Re: Low buck projects- Let's see 'em!
Here is an instrument pod that I built for a raymariene c90. I molded it out of fiberglass using a rubbermade container as a mold. I also molded the pedestal guard for the area thats inset where it attaches. Because I already had some leftover glass and awl grip the only thing I had to buy was the $6 rubbermade. It still kinda looks like a tupperware container but considering the price of an actual Navpod...
Yu & Frank
StormBay is offline
The Following 2 Users Say Thank You to StormBay For This Useful Post:
highcs (09-15-2013), SloopJonB (05-22-2013)
post #682 of 1562 Old 05-22-2013
Senior Moment Member
SloopJonB's Avatar
Very slick. The indentations on the side look like they are there to provide a mounting spot for bracketed electronics of some sort - VHF etc.
SloopJonB is online now
post #683 of 1562 Old 05-22-2013
TakeFive's Avatar
Originally Posted by Cruiser2B View Post
Well. I needed a new holding tank, one was stinkin and only 6 gallons, decided to take advantange of available space so I made one. New one holds 14 gallons and still fits in same location as old one
All said and done I had about $110.00 including hose, fittings and materials.
I posted quite a few pics on my blog, here is the link....i hate resizing pics
http://svsalacia.blogspot.com/2013/05/crap.html.
so far it holds water just fine
A few years from now, after a few weeks of hot July Virginia weather, I don't want to even think of how your porous wood box is gonna stink up your boat. At some point it's going to rot through and leave an awful mess to clean up.
But it was cheap!
Did you consider coating the whole insides with epoxy or barrier coat? At least that would have eliminated the porosity and prevented rotting from inside out.
Rick S., Swarthmore, PA
TakeFive is offline
post #684 of 1562 Old 05-22-2013
TakeFive's Avatar
My nice big fenders would pick up a graphite color from the black dock floats, and then transfer it to my hull as they rolled around:
Fender covers are ridiculously expensive, and they just get disgusting looking anyway, so I made my own from old T-shirts:
They do look like the boating equivalent of trailer trash, but they're functional and cheap enough that I'm not reluctant to change them out whenever needed.
Here's "wit and witout" as they say in South Philly:
oceangirl and Gregrosine like this.
TakeFive is offline
post #685 of 1562 Old 05-23-2013
SloopJonB's Avatar
But it was cheap!
Read it again - 5 coats of epoxy.
Group9 likes this.
post #686 of 1562 Old 05-24-2013
Barquito
Barquito's Avatar
That will do the trick. If it wasn't marine ply, it might crack due to voids in the wood. I would have also put a layer of glass in there. But, even if it does leak after 8 or 10 years, just replace it, or repair it (and keep the expensive fittings).
Valiant 32
Barquito is online now
post #687 of 1562 Old 05-24-2013
Cruiser2B's Avatar
yes, it indeed does have 5 coats of epoxy, I also fiberglass taped all the seems on the inside and used 2 layers on the entire outside of the tank. If that does not work I may just buy a bucket with a long string...
I put water and chemical in the tank for a week here at the house then dumped it. Did not have any evidence of leaking. '
Also, this was my first try at build a structure with wood,epoxy and fiberglass, I think it turned out well. Time will tell.
Group9 likes this.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #688 of 1562 Old 05-24-2013
Cruiser2B's Avatar
But it was cheap!
Care to enlighten me on what is funny about trying to complete a DIY project?
I wouldn't call it cheap either, I used good products. I chose this route because I was reading on this board actually about a newer boat with a stainless holding tanks that had corroded. so I figured I'd give it a shot.
post #689 of 1562 Old 05-24-2013
TakeFive's Avatar
I initially saw your caption that mentioned epoxy in the joints, but I did not scroll down far enough to see your reference to 5 coats on all the wood surfaces.
I was mistaken. Sorry about the error. Your design and execution look fine. Good job!
I would go back and delete my error, but you guys have saved it for posterity by quoting it. So there's not much I can do at this point.
TakeFive is offline
post #690 of 1562 Old 05-24-2013
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
lesson learned I guess read the whole post before replying
hotdogs likes this.
Bill-Rangatira is offline
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
