Low buck projects- Let's see 'em! - Page 70 - SailNet Community
 1223Likes
post #691 of 1560 Old 05-24-2013
Cruiser2B's Avatar
Re: Low buck projects- Let's see 'em!
I initially saw your caption that mentioned epoxy in the joints, but I did not scroll down far enough to see your reference to 5 coats on all the wood surfaces.
I was mistaken. Sorry about the error. Your design and execution look fine. Good job!
I would go back and delete my error, but you guys have saved it for posterity by quoting it. So there's not much I can do at this point.
Thanks for the reply....I understand.
I will keep all posted on how it works out.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #692 of 1560 Old 05-24-2013
Closet Powerboater
MedSailor's Avatar
Originally Posted by Cruiser2B View Post
Well. I needed a new holding tank, one was stinkin and only 6 gallons, decided to take advantange of available space so I made one. New one holds 14 gallons and still fits in same location as old one
All said and done I had about $110.00 including hose, fittings and materials.
I posted quite a few pics on my blog, here is the link....i hate resizing pics
Adventures of Salacia: Crap!.
so far it holds water just fine
This is so awesome!!! I've been recently figuring how to re-arrange all the tankage in my boat and the only things standing in my way right now are the cost of fabricating new stainless water tanks and the time and effort required to design and commission them.
While your tank might give you years of service, and there are some production boats that have wood/glass holding tanks I wouldn't trust my nonexistent epoxy skills to build a tank to hold diesel or poop. Lucky for me, the only tanks I need built (or to build) at this point are water tanks.
If one of them leaks it won't be catastrophic because the water is harmless, I'll have the ship's water supply decided across at least 2 tanks, and the tanks you've shown us are easily repairable!
Nicely done! I have once built a small boat out of plywood and glass, and it successfully kept water out.... so I can probably build something similar to keep water in.
Great idea! Thanks! (this'll also help me get more confident with glass work)
MedSailor
MedSailor is offline
post #693 of 1560 Old 05-25-2013
rhr1956's Avatar
MedSailor
There isn't much to working with epoxy. The metering pumps and West Marine make is idiot proof. Five pumps of resin needs five pumps of hardener. If you can count, you can epoxy!
bljones likes this.
rhr1956 is offline
post #694 of 1560 Old 05-25-2013
Cruiser2B's Avatar
I agree, just make sure all surfaces are clean, i kept actetone and wipes handy....good luck
post #695 of 1560 Old 05-25-2013
TakeFive's Avatar
Also, don't mix up too much at once. It can heat up and you'll get a runaway reaction going.
Blue Eagle likes this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #696 of 1560 Old 05-25-2013
Senior Moment Member
SloopJonB's Avatar
Pouring it into a flat pan like a paint tray will slow that down - the more surface area the better.
SloopJonB is offline
post #697 of 1560 Old 05-25-2013
TakeFive's Avatar
Agreed, shape of the container can have a big effect.
TakeFive is offline
post #698 of 1560 Old 05-25-2013
rhr1956's Avatar
For small projects I mix the epoxy in a heavy duty paper dinner plate...the cardboard kind. Great for mixing in fillers and stuff.
rhr1956 is offline
post #699 of 1560 Old 05-25-2013
mitiempo's Avatar
MedSailor
Make sure you source the correct epoxy for water tanks. Standard epoxy like West is not good for potable water.
MedSailor and SloopJonB like this.
Brian
mitiempo is offline
post #700 of 1560 Old 05-26-2013 Thread Starter
bljones's Avatar
A two-fer- low-buck swim ladder rungs and low-buck steering gear repair.
Dock Six Chronicles: Low-Buck Launch: Splash 2013
It's 5 o'clock somewhere:
bljones is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
