Low buck projects- Let's see 'em! - Page 71 - SailNet Community
 1230Likes
post #701 of 1562 Old 05-27-2013
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
Talking Re: Low buck projects- Let's see 'em!
Gluing the fabric down is a great idea - saves all that sewing (which I can't do anyway!)
Just out of curiosity, why did you go to all the trouble of slitting noodles instead of simply using pipe insulation?
Also, how did you rig things up to get a straight cut from end to end? I've always found cutting any kind of tubing without having the cut wind around the tube a bit is very difficult without some sort of jig.
Why noodles instead of pipe insulation? Because I like Big Uns! :-)
The new pool noodles are available in 3" dia. They will also add a bit of flotation. This old fiberglass has no flotation chambers built in.
As for cutting the slit, a simple knife cut works fine. I admit that my first try had a bit of a spiral to it but I paid closer attention to the second one and it came out fine.
jimgo likes this.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
The Following User Says Thank You to heinzir For This Useful Post:
SloopJonB (05-30-2013)
post #702 of 1562 Old 05-29-2013
"throwing in the towel"
Send a message via Yahoo to fortis est veritas
Quick question to the experienced sailors: I purchased a columbia and it needs bottom paint (has it but it's ugly and weathered). This year I'm going to keep it close to home, in a fresh water lake in Kentucky and I wanted to know if their is an inexpensive alternative to bottom paints to get me through this season. I plan on getting her seaworthy over fall and winter, and setting sail for the Caribbean early 2014.
Advice for the new guy would be greatly appreciated!
fortis est veritas is offline
post #703 of 1562 Old 05-29-2013
Barquito
Barquito's Avatar
The cheapest way would be to not paint it at all. There is probably some left over from last season. Will probably get a good growth of whatever grows in your lake. Pressure wash and scrape it all off in the fall. However, if it was me, I would just go ahead and get some bottom paint on. Just a quick rough sanding, and slop it on there.
Valiant 32
Barquito is online now
The Following User Says Thank You to Barquito For This Useful Post:
fortis est veritas (05-29-2013)
post #704 of 1562 Old 05-29-2013
Back to just the Jon boat
therapy23's Avatar
I would start a new thread.
therapy23 is offline
post #705 of 1562 Old 05-29-2013
Therapy 23...still new tot he forum, and haven't exactly got the "new thread" thing figured out; however, don't seem to understand why you feel the question didn't fit the thread "Low buck projects?"
post #706 of 1562 Old 05-29-2013
No more curry buffets
Ritchard's Avatar
Fortis,
This thread is kind of about finished cheapskate special projects. Bottom paint is simply regular maintenance. That having been said, as Barq suggests, either just sail it - you can give it a quick clean nice a month while its in the water - or slap some quick and easy paint on there . Bottomkote XXX would do nicely and is affordable.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
The Following User Says Thank You to Ritchard For This Useful Post:
post #707 of 1562 Old 05-29-2013 Thread Starter
bljones's Avatar
a couple of quarts of bottomkote is less than $90, add in $10 worth of drywall sanding screens and a couple of days of gruntwork and your bottom is ready to go.
It's 5 o'clock somewhere:
bljones is offline
The Following User Says Thank You to bljones For This Useful Post:
post #708 of 1562 Old 05-29-2013
Asleep at the wheel
jimgo's Avatar
Becaus this thread really isn't about asking new questions, it's about people showing off their handiwork (aka low buck projects).
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #709 of 1562 Old 05-29-2013
One of None
deniseO30's Avatar
Fortis these items are cheap!
eherlihy likes this.
My last project!
deniseO30 is offline
The Following User Says Thank You to deniseO30 For This Useful Post:
post #710 of 1562 Old 05-29-2013
therapy23's Avatar
I guess it is because the thread is directed toward those that have done a "low buck" project and are showing it off.
There are a lot of threads on bottom paint.
Usually someone with a question goes to the area, like maintenance, and starts a new thread. (Up in the top left is a button for new thread).
Then the specific question (or answer, or whatever) is presented and others can give their input on that particular idea/problem.
A lot of times in a thread there is a tangent begun that takes the thread off track from the original question. It can go far, far away and no longer applies to the original idea or thought. It is termed "thread drift". A thread about a small outboard not starting can end up being all about replacing fuel tanks. Someone looking for info on tanks may never find it because it is not really "there".
Not trying to bully. Just trying to be explanatory.
Welcome to Sailnet. There is a lot here.
bljones likes this.
The Following User Says Thank You to therapy23 For This Useful Post:
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
