Low buck projects- Let's see 'em! - Page 74 - SailNet Community
 1230Likes
post #731 of 1562 Old 06-24-2013
Glad I found Sailnet
Bene505's Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by heinzir View Post
...As for cutting the slit, a simple knife cut works fine. I admit that my first try had a bit of a spiral to it but I paid closer attention to the second one and it came out fine.
Would a bit of spiral help keep it in place?
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is online now
post #732 of 1562 Old 06-24-2013
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
Might help a little but I chose to glue the finished noodles directly to the dinghy gunwales top and bottom.
From El Toro and Mirror Dinghies
The colored blocks are giant Legos used as spacers to keep the edges of the slip apart so they don't accidentally get glued together.
The black bottom is epoxy mixed with graphite powder to make it slide down my homemade plywood ramp more easily. The heavy rains the last few weeks have caused the lake to be abnormally high, so the shoreline doesn't really show in the pictures. I usually have to cross about 10' of rip rap to get the boat in the water. I slide it over three 2' x 3' plywood panels that are hinged together with zip ties so they fold up for storage against the fence.
This is not my property by the way. It is an empty lot owned by the city and designated "commons." They license about 15 docks and my one mooring buoy for this location, for a nominal fee, of course. I live about a block and a half away and keep my dinghy up against the fence.
bljones and jimgo like this.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
post #733 of 1562 Old 06-24-2013
Junior Senior
heinzir's Avatar
Here's another super low buck "project" for trailerable boats. Slit some 12" or 18" pool noodles and slip one over each shroud and turnbuckle. Use tape to keep the slits closed. The noodles will protect the deck finish from being scratched by the shroud wires while travelling. I keep the noodles on while raising the mast; they keep the turnbuckles aligned properly and prevent kinks. Once the mast is up, I cut the tape, remove the noodles, and toss them in the back of the van to await the trip home.
From Chiquita
FinallySailing likes this.
Henry
heinzir is offline
post #734 of 1562 Old 06-26-2013
Bene505's Avatar
Originally Posted by Bene505 View Post
In the past, when we dinghy up to the boat it would be dark and one of us would have to turn on the nav lights or cockpit lights to light-up the boarding area.
So this winter I put two LED strip lights on the underside of the bar that connects the dinghy davits. Then I installed 3-way switchs like the kind you have at the top and bottom of your stairs at home. One of the switches is at the nav station. The other is a pull switch, like you see on ceiiing fans or closet lights, with the cord running through a vent to the transom.
When we dinghy up to the boat this summer, we can pull the cord and have instant lights.
It's actually a bit of a surprise for my wife. We'll see if she likes it.
Regards,
Brad
She loved it. We finally got back to the boat at night, earlier this week. I said "Pull the cord." The 7 feet of LED strip under the davit bar instantly lit up the whole dinghy.
Regards,
Brad
bljones, utchuckd, jimgo and 1 others like this.
post #735 of 1562 Old 06-26-2013
G20
G20's Avatar
Hi everyone,
Attached are some pics of new wood companionway slides I installed yesterday. The original ones were plastic and had cracked in a number of places. They are made out of Sipo and lucky enough for me....cost nothing! My sister owns a wood shop and had some scrapes laying around. They were simple to mill up with all of her equipment.
Total price to me was 45 minutes of time, 5 dollars in stainless hardware and a tiny bit of butyl tape. Works much better than the old ones and they have made the sliding action quite a bit quieter.
-Chris
Faster, bljones and dvuyxx like this.
G20 is offline
post #736 of 1562 Old 06-26-2013
G20
G20's Avatar
And here is another! Found out my mast step had rotted (shocker) earlier this season and completed my first epoxy/fiberglass repair.
Total cost in material was about 80 dollars including a 30 dollar quart of high build primer of which I used like an ounce out of. Sorry I don't have any more "in progress" photos but I choose to glass in a 3/8th inch plate of 6061 aluminum vs replacing the wood. The holes going through the deck and plate were drilled oversized and potted so the metal is completely incased. I hope that was an OK decision as that metal isn't coming out now! I don't think 80 bucks is a bad price for a mast step repair.
-Chris
G20 is offline
post #737 of 1562 Old 06-26-2013
rhr1956's Avatar
Did you use a Forstner bit to drill the holes, or was that from a hole saw?
rhr1956 is offline
post #738 of 1562 Old 06-26-2013
G20
G20's Avatar
Yeah, my "exploratory" holes were a bit on the large size. I used a 1/2' forstner, of which I learned not to do as it grabbed terribly at the glass and wanted to pull itself into the hull instantly.
The largest hole was from the old electrical deck connection for the mast light. I have yet to replace the light or the connection, project for another day.
G20 is offline
post #739 of 1562 Old 06-26-2013
Old enough to know better
Regards,
Brad
well at least you did not ask her to pull your finger!
sounds like a good worthwhile effort. How was the light? I know a lot of times light from an LED is quite directional and that is great for task lighting, but without some sort of diffuser they don't give much spill so do you get much light on the aft deck? I am sure it makes it much more comfortable going up the swim ladder. Now all you need is one of the remote light switches.
miatapaul is offline
post #740 of 1562 Old 06-26-2013
Asleep at the wheel
jimgo's Avatar
I found a vendor on eBay who sells cut-offs from large rolls of Sunbrella. I got the tan (wheat) Sunbrella I wanted for $8/yard. So, I'm in the process of making a dodger and bimini for the boat (frames were already there when I bouth the boat), and have some "extra" material, so I decided to do lifeline/pushpit covers. These are pool noodles that have been slit to fit over the rail, then cut to length. The ends have polyester cord sewn in so I can pull them closed (thus hiding the pool noodles) and there is velcro along the entire length of each pad. The pool noodles were $1 each at the dollar store, and I think I used 6 of those ($6). I used somewhere between 1 and 2 yards of material, so we'll call it $16. The Velcro was bought on eBay (it's probably not name-brand Velcro) for about $10 (including shipping), and I used good thread that I got from Sailrite ($9 for the entire spool, which I'm using for the other projects, too). So, for about $40, I have custom-made pads that go all around the cockpit. They make it MUCH more comfortable to lean against the rail than before.
I also made the sail cover as part of this process. That was about 5 yards of material ($40) plus twist-lock connectors ($15) and 2" wide velcro ($10) plus some heavy duty vinyl for chaff protection inside the cover ($15 remnant at Joanne's). So, for about $80, I have a custom-made sail cover.
I need to put something at the aft end of the cover to keep it tighter so it looks nicer...
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
