Low buck projects- Let's see 'em! - Page 75 - SailNet Community
 1223Likes
post #741 of 1560 Old 06-26-2013
Re: Low buck projects- Let's see 'em!
Originally Posted by jimgo View Post
I need to put something at the aft end of the cover to keep it tighter so it looks nicer...
Nice work... just add some ties to stretch the sail cover back to the (taut) topping lift..eezy peezy lemon squeezy... (as my granddaughter would say )
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
jimgo (06-26-2013)
post #742 of 1560 Old 06-27-2013
WinterRiver's Avatar
A couple recent low-bucks projects:
I was tired of tying a tarp over the pedestal. The pedestal cover project used about 3/4 yard of Sunbrella I had left over. It was just barely enough for the top piece. For the under side I bought some cheapo outdoor canvas at the local fabric store. The color match isn't perfect, but it's close enough. Cost: about $10.
Last season I removed the suede wheel cover that was disintegrating in a couple places. My daughter and I wrapped the wheel in 300' of paracord. I think the navy coordinates well with the rest of the canvas, and I hope it will stay cleaner than white would. Cost: about $25.
This spring the top of the pedestal cover was beginning to wear through where we grab it. Enter the pieces of suede from the wheel cover that were too good to throw away. It was already perfectly shaped to fit, and the holes made it very easy to sew. Cost: free.
CLucas, Bene505, SloopJonB and 1 others like this.
WinterRiver is offline
post #743 of 1560 Old 06-28-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Awesome job on the corded wheel cover.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #744 of 1560 Old 06-28-2013
Nice
Pcpk is offline
post #745 of 1560 Old 06-28-2013
No more curry buffets
Ritchard's Avatar
Talking Re: Low buck projects- Let's see 'em!
No kidding, great job. Can you show us the knotting techniques?
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #746 of 1560 Old 06-28-2013
Ritchard's Avatar
After months of spending too-damn-much money on projects to post them here, I finally have a low-buck project I can offer.
Among the many upgrades I wished to make to my old Endeavour 32 was a cockpit table. Being even cheaper than BLJones, there was no way I could justify the cost of an Edson or Lewmar teak table, and those starboard plastic ones just don't do it for me. I had read all the threads here about finishing a table with varnish, and here's what I came up with:
Here's a shot of its very early life.
Edit to add: whoops, I just realized that's another piece I made up for stern rail seats. The method is exactly the same, however.
As wide planks of full dimension teak are now worth a kings ransom, I epoxy laminated the table together out of strips of 1x3. The epoxy adhesive was thickened with two parts teak sanding flour to one part colloidal silica, this made a strong glue that comes out just about the right colour. For alignment purposes the strips are joined with biscuits as well. I made one main piece per evening over several evenings. The three main pieces were then sent through a planer, the knives of which they made short order of. Then the main pieces were sanded, and the rest of the detail pieces were epoxied on afterwards using similar methods.
What follows is an awful lot of sanding, filleting joints, more sanding, then 14 or 15 coats of Minwax Spar Urethane, tempered with an awful lot more sanding between coats. The final couple of coats were completely wet sanded to achieve the truest flattest finish I could manage. The wet sanding alone was probably four or five hours. The last coat provides the gloss, with just the lightest wet sand with 2000 grit to knock off any tiny and inevitable dust pimples.
If you look carefully, there are many flaws in the finished product, but most of them will never be noticed by anybody but me. I figure these flaws make it real. I also learned a great deal about this kind of woodworking, something I had never done before.
I started this project in January, and have worked on it as I have had time between my other boat projects this spring. I finished it just an hour ago, and I couldn't be more pleased with the outcome, so quickly logged in here to show it off.
So the tally?
About $50 or 60 in teak, a few bucks worth of epoxy and thickener, maybe 15 bucks in various sandpapers, $15 in varnish, $10 in foam brushes, maybe $18 in hardware. I guess I slipped over the $100 threshold.
Well nevermind then. Move along.
So the real cost? If you took my hours invested at my regular billing rate, the table is worth somewhere in the neighbourhood of $6000. Perhaps I should have just bought the damned thing after all. I wouldn't be as proud of a store-bought table, but am I $6000 proud?
miatapaul, bljones, jimgo and 2 others like this.
Ritchard is offline
post #747 of 1560 Old 06-28-2013
Asleep at the wheel
jimgo's Avatar
Ritchard, how can you even keep such a POS on your boat? I'll tell you what...since I'm such a nice guy, I'll let you send that one to me, and I'll make sure it stays well out of sight so you don't ever have to see it again. I even promise that, in any pictures I post here, I'll be sure to hide it with charts, plates, and other stuff, too.
Ritchard and Rhapsody-NS27 like this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #748 of 1560 Old 06-28-2013
jsaronson's Avatar
Ritchard, Nice work!!
What did you use for hardware?
jsaronson is offline
post #749 of 1560 Old 06-28-2013
rhr1956's Avatar
Richard. I have a friend that works at West Marine and he tought me something about finishing wood projects. He is also a master cabinet maker but retired from that and sold his company. (I think he works at WM for the discounts so he can maintain his 50' motor-sailer, but that is another story.)
Anyway, I always admired his wood finishes and one day asked him how he achieved the look. He also uses the MinWax Spar Urethane instead of Varnish. After finishing his piece with several coats (I think he said 7-8 coats) of gloss product he switches to satin product for the final coat. It knocks down the hard shine but does not effect the "depth" of the finish. The results are amazing.
rhr1956 is offline
post #750 of 1560 Old 06-28-2013
Ritchard's Avatar
jsaronson
The hinges can be found here:
Lee Valley Tools - Important Announcement
Lee Valley is like a wonderland for woodworking.
Ritchard is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
