Low buck projects- Let's see 'em! - Page 80 - SailNet Community
 1223Likes
post #791 of 1560 Old 07-29-2013
rhr1956's Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by dem45133 View Post
Why? What are they mfg it from that can't do oil? Can't be much good then.
I said "oil" but should have said "flamable liquids"...but anyway, I used the first pump I had to empty some used motor oil from a drain pan to a one gallon plastic bottle. It pumped about a 1/2 quart and was toast. Notice Label in pic
rhr1956 is offline
post #792 of 1560 Old 07-29-2013
Old enough to know better
Well I don't think motor oil is really considered flammable. Yes, it will burn you you really have to try to get it to burn, and I don's see a spark igniting motor oil, and I imagine that is the issue it is warning about, spark and or heat causing problems. The flash point of motor oil is around 450 degrees, so I think it should be OK in a drill powered pump as the pump likely would melt before it started to make the motor oil flamible. The last one I had included plastic tubes to be able to pull motor oil out the dipstick and even included oil change instructions. I used to use them to pump muriatic acid through a boiler heating coil, as we had really hard well water. Had to do it about every 6 months. I could get about two uses before it started leaking. Then I would pitch them and get a new one. I really don't suggest using one for Muriatic acid as it is really nasty.
miatapaul is offline
post #793 of 1560 Old 07-30-2013
Good heads up! I need not worry though because I have an outboard and will only be draining water, and maybe the occasional whoops from using the head in rough weather.....
jeepjeff is offline
post #794 of 1560 Old 08-02-2013
Storm- sorry, was away for a few days. i got the wood from certainlywood.com
i've always admired the work on old pieces of furniture, and really wanted to try it. so, i got the exotic sampler a few years ago, did a small oak leaf inlaid into my kitchen table, and the rest is history. i was amazed at how much veneer i got for $40- there's enough stuff in there to last me years! then, you look at all the pieces they have in the inventory, and it makes we wonder if i've chosen the wrong profession...
i use an exacto knife, some folks use a super fine jigsaw. be sure to get some marquetry tape from Certainly as well- some species of wood easily split/splinter when you cut or handle it. plus, you tape everything together to hold the pieces in place while glueing. it's a specialized gentle tape that doesn't stain or damage the thin veneers.
it's like unwrapping a present when you sand off the tape and see what you've created!
RyanL is offline
The Following User Says Thank You to RyanL For This Useful Post:
StormBay (08-03-2013)
post #795 of 1560 Old 08-27-2013
Originally Posted by jeepjeff View Post
I made a bilge pump using my rechargeable drill, a couple old pieces of garden hose, and an small "Drill Pump." The drill pump is self priming and cost about $6 - I already had the drill and hose laying around. I'll try to attach a picture of the pump, if successful you will see the stem on the back of the pump that the drill drives. This thing moves a lot of water fast and you can direct the water anywhere you put the outlet end of the hose.
Could also be used for a little washing up of the boat if desired.
Great idea! I'm off to get one! Would work well as a backup if your batteries went flat.
Plus, I wanted to subscribe to this awesome thread! So many great ideas and talent!
trkarl is offline
post #796 of 1560 Old 08-28-2013
Fresh water refugee
katsailor's Avatar
We use small transfer pumps in my industry to transfer oil. Because of the viscosity of oil most pumps fail after a very short period of time. Some failures may be attributed due a reaction between the fluid and the impeller. Jabsco make a transfer pump suitable for this application.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #797 of 1560 Old 08-30-2013
Andrew65's Avatar
I anchor off and solved my dink from tapping the hull at night and waking me up by threading my painter through a 5 foot piece of pvc tubing before bedtime to hold it off. Works like a charm, no more dingy tap. It`s not my idea. Got it from a magazine, but very effective and quiet.
joyinPNW likes this.
Andrew65 is offline
post #798 of 1560 Old 08-31-2013
Remember you're a womble
PaulinVictoria's Avatar
I have a couple of GPS receivers (that were low-bucks in themselves), one is to feed the chartplotter (another low-buck item), and the second feeds the VHF (another low-buck item!). I wanted this level of redundancy, and also it means I don't have to switch on the chartplotter in order to have the position into the radio.
Anyway, rather than buying a rail mount for the two receivers, I made a little mount for them out of some teak ply, not only does it look rather neat, it means no holes drilled in the boat, it uses the existing deck plate and the dorade is fully functional.
Faster and bljones like this.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #799 of 1560 Old 09-22-2013
Tundra Down
downeast450's Avatar
A new instrument panel.
I added a tach and built this one for our I-28.
Insturment Panel For Sailnet Slideshow by gfatula | Photobucket
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #800 of 1560 Old 09-22-2013
Senior Moment Member
SloopJonB's Avatar
Nice. What was your thinking re: building it up with the "filler" instead of just using a sheet of white plastic?
Faster likes this.
SloopJonB is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
