Low buck projects- Let's see 'em! - Page 86 - SailNet Community
 1223Likes
post #851 of 1560 Old 10-20-2013
midlife crisis member
AllThumbs's Avatar
Re: Low buck projects- Let's see 'em!
I always wanted a new rudder to replace the slab rudder that the factory built. I started with a lamination of plywood, then built a vacuum bagger and applied 3 layers of 9 oz cloth on each side. All three of the layers on each side are wrapped around the edges, making the edges 6 layers thick. I knew without the vacuum, it would be a terrible mess trying to get the heavy cloth to go around the sharp edges.
The vacuum pump is a small fridge compressor, some hose, and a mason jar. The jar is to prevent epoxy from getting into the compressor.
So far it's working. Tomorrow we will turn off the pump and check it out.
erps and JWizzz like this.
AllThumbs is offline
post #852 of 1560 Old 10-20-2013
Asleep at the wheel
jimgo's Avatar
Very nice! Where did you get the bags?
Blue Eagle likes this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #853 of 1560 Old 10-20-2013
AllThumbs's Avatar
I am just using builders 6 mil vapor barrier plastic and butyl tape to seal it.
jimgo likes this.
post #854 of 1560 Old 10-20-2013
Asleep at the wheel
jimgo's Avatar
Nice! It looked like a welded seam at first. Great idea!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #855 of 1560 Old 10-21-2013
AllThumbs's Avatar
The pump was getting a bit hot so I put a small fan on it and it stayed luke warm. I left the pump run all night.
Fresh out of the bag and after a little "deburring". Lots of fairing to do.
fred1diver likes this.
I sail.
post #856 of 1560 Old 10-21-2013
Old enough to know better
There seems to be nothing that butyl can not do!
jimgo likes this.
miatapaul is offline
post #857 of 1560 Old 10-22-2013
Tundra Down
downeast450's Avatar
Nice! I have been working on a vac bag system and didn't think of an old fridge compressor. I will give it a try. I have an old freezer that is headed to the dump. Thanks!
It looks good!
Down.
Islander-28, Marshall Sandpiper
downeast450 is offline
post #858 of 1560 Old 10-27-2013
Re: Low buck projects- Let's see 'em! My cheap but working fridge
I did the same with my p30, I used parts from a water cooler, including the thermostat on a 80 degree day box goes down to 37. Planning to operate the system with a 2kw inverter 240 watt panel to charge battery bank (500wh) will post back with results
reilly is offline
post #859 of 1560 Old 11-02-2013
Replaced my companionway boards today. Lowes carries a plastic board now that is 11 inches wide and only 5/8 inch thick so it fit really well. The board was $30. The downside is they are a little heavy, but I plan to put some spare smoked acrylic in the middle one and a vent on the top one so that should help. The bottom one probably won't come out much.
Before
After
Sent from my iPhone using Tapatalk
tschmidty is offline
post #860 of 1560 Old 11-03-2013
1982 Skye 51
obelisk's Avatar
here's a zero dollar project. i found the bucket floating by the boat and the plexiglass in the dumpster (the treasures some people throw away!!). a hot knife and a little 5200 and now, with my "lookey-bucket" i don't have to jump in the water to check my anchor or see how vibrant the reef is before snorkelling.
Bene505, 67Therapy, jimgo and 2 others like this.
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
obelisk is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
