Low buck projects- Let's see 'em! - Page 89 - SailNet Community
 1230Likes
post #881 of 1562 Old 11-08-2013
midlife crisis member
AllThumbs's Avatar
Re: Low buck projects- Let's see 'em!
Want some mood lighting that doesn't look too cheesy for those warm summer evenings drinking wine in the cockpit?
Start with one of these solar garden lights. And it has to be this one. This is the only one I have seen that doesn't look like you made it from a $5 garden light (Although it does cost $5 at Canadian Tire, unless you get it on sale. Then it's $3.
Remove SS post, cut off 3/4" long plastic stud/post adapter. Make it flush if you can so it can sit on a table if desired. I used a sharp utility knife.
Drill small holes into the top of the SS cover. 180 degrees apart is good. I even made sure the square solar top was at right angles to the holes? It's the kinda guy I am I guess.
Add a copper or even SS wire, bent strategically, to hang it from. Use a clip or an S hook to hang it under the bimini or from a life line or where ever. Your friends will think you spent $40 for a fancy SS boating light.
tdw, eherlihy, bljones and 1 others like this.
I sail.
AllThumbs is offline
post #882 of 1562 Old 11-08-2013
AllThumbs's Avatar
These are nice to hang around your pergola or gazebo or whatever at home too. Just make sure they can get some sun during the day.
I sail.
post #883 of 1562 Old 11-08-2013
This isn't really any one particular project, but this is MUST HAVE for any quick turn low-buck projects: Instamorph (Polycaprolactone), or shapelock, friendly plastic - there are a number of brands. It is a non-toxic plastic that you can form yourself by hand. Simply place it in hot (NOT boiling) water for a few minutes and once it turns from white to clear just shape the plastic any way you want.
Need a wrench you don't have? Well, form a diy wrench in-place over the fitting with instamorph.
Google it, it's pretty amazing stuff. You can tap it and drill it (slowly), but sanding doesn't work well (it heats up and gets soft). Since you tend to form it by hand the results often don't look very good, but it is functional.
I haven't used it for much more than making a little holder to keep a specific allen wrench near a fitting that needs it often. However, it's the kind of thing I'm glad I keep on the boat in case I need something when underway and Lowes or West Marine is unreachable.
The following pics are from the web to give you an idea of what it can be use for in a pinch.
Reefpoints is offline
The Following User Says Thank You to Reefpoints For This Useful Post:
Delezynski (11-08-2013)
post #884 of 1562 Old 11-09-2013
and where do get that product?????
fred1diver is offline
post #885 of 1562 Old 11-09-2013
Glad I found Sailnet
Bene505's Avatar
Instamorph
Skip to 4:50 on the video.
It's on eBay too.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #886 of 1562 Old 11-10-2013
Tundra Down
downeast450's Avatar
Parts bins, tool drawers, tape storage, hardware storage. These little snap closed flat clear plastic tubs have become very useful to me. From displaying small tools in an easily accessed "drawer" to containing the parts when I am rebuilding a carb to storing butyl tape flat and clean to providing me with convenient collections of abrasives and /or an epoxy reppair kit. AND THEY STACK! Thank you Sara Lee sugar ham and turkey ham.
Down
eherlihy likes this.
Islander-28, Marshall Sandpiper
downeast450 is offline
post #887 of 1562 Old 11-12-2013
Tundra Down
Shock cord hooks.
These little gems turn 1/4" shock cord into quickly adjustable, any length bungees without any knots. I buy both 1/4" shock cord and the "crab pot hooks" at a marine store that serves commercial fishermen. I shared these in a post on tarping the boat. The hook fits a grommet. The shock cord fits into a compression slot. Stretching the shock cord allows it to "snap" into the slot.
A 50 pc. bag is about $10.00. They last forever.
Down
post #888 of 1562 Old 11-12-2013
Nice table. I simply bought a folding table with a fake marble top that actually fits nicely in the cockpit and folds nicely into the locker.
Also had a "bimini top" made that goes over the boom, I don't normally use the main, and ties down to existing hardware. Will provide pics of both soon as I get them .
alechich is offline
post #889 of 1562 Old 11-12-2013
Senior Moment Member
SloopJonB's Avatar
Downeast - cut your shock cord with a heated blade and it won't fray like that.
SloopJonB is offline
post #890 of 1562 Old 11-12-2013
Tundra Down
Yup! Most times I do, Deah! Thanks.
Down
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
