Low buck projects- Let's see 'em! - Page 92 - SailNet Community
 1230Likes
post #911 of 1562 Old 12-09-2013
Senior Moment Member
SloopJonB's Avatar
Re: Low buck projects- Let's see 'em!
Denise, I could really learn to hate you!
That thing is freakin' gorgeous - you are a true crafts"person".
jimgo likes this.
SloopJonB is online now
The Following User Says Thank You to SloopJonB For This Useful Post:
deniseO30 (12-09-2013)
post #912 of 1562 Old 12-09-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Very nice. I could use a good workshop table like that.
Well done!
Originally Posted by deniseO30 View Post
this really is low buck since the beech lumber was free. I have less then a $100 in hardware including the tail vise slide that was on sale for $55.
More pics here;
http://www.sailnet.com/forums/off-to...ml#post1204401
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
The Following User Says Thank You to Rhapsody-NS27 For This Useful Post:
post #913 of 1562 Old 12-09-2013
One of None
deniseO30's Avatar
Thank you everyone, yes it came out pretty nice, hard to believe it's going to be "trashed" with all kinds of woodworking projects upon it as time goes by.
This was "free" Laun boards and ply. it fits the top of the stove in my boat.
can't see them, the dovetail keyed corners.
Rhapsody-NS27 likes this.
My last project!
deniseO30 is offline
post #914 of 1562 Old 12-09-2013
TakeFive's Avatar
Wow, Denise, your workmanship looks great! I guess you do a lot more than bend sheet metal!
Rick S., Swarthmore, PA
TakeFive is offline
The Following User Says Thank You to TakeFive For This Useful Post:
post #915 of 1562 Old 12-10-2013
awesome thread nothing to add yet till i get my dream boat
redbaron is offline
post #916 of 1562 Old 12-11-2013
Delta-T's Avatar
Nothing like a shower...Engine water heat exchanger. I think Jeep makes one like this. That is where I got the idea. I would assume this would work better with a sealer engine cooling system. Mine is raw water (salt in my case) and has been in use with no issues for over 12 years. I'm not looking to have a hot shower, but just to temper the tank water. Be very careful, the water can start off scolding hot! I would suggest adding a mixing valve to add cold water and adding a more even temp. and longer run time.
I ran the hot water to a hand held sink type spray head I keep coiled up in the Port Lazarette. Can also be used to wash down the cockpit. Or two birds with one stone.
What this plan does not point out is a 2 1/2" to 3/4" reducer on both ends.
And that would be my rebuilt Graymarine Sea Scoot 91 engine in that pic. Did that myself. Love to keep the original if possible.
jimgo likes this.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #917 of 1562 Old 12-12-2013
Delta-T's Avatar
PVC winter tarp frame:
No screws, no metal hardware or sharp edges to rip covering, nothing but rope and PVC (boat friendly), easy to set up and easy to store and open inside space for working. Can be made taller or shorter for your needs.
With the pitched short roof snow was not an issue so no structural ridge beam is needed, as long as there is no roof load. You can also use a 90 deg. elbow at the to ridge to get more pitch, but you will then have to tie center rope off to mast to keep for side to side movement or add interior rope gussets. And if in doubt, add a rope from the 45 deg elbow to the other 45 deg elbow on each frame section.
jimgo and Rhapsody-NS27 like this.
Eric
Delta-T
Delta-T is offline
The Following User Says Thank You to Delta-T For This Useful Post:
jimgo (12-12-2013)
post #918 of 1562 Old 12-12-2013
SloopJonB's Avatar
Put another one of those on it and run engine coolant through it - your engine will love you for it.
post #919 of 1562 Old 12-12-2013
Delta T--How have you attached the PVC pipe to your hull?--I think your idea is great so thanks for posting-Chris-New Zealand-Herreshoff 38' Leaboard Ketch
Delta-T likes this.
White Knight is offline
post #920 of 1562 Old 12-12-2013
mitiempo's Avatar
The easiest solution would be to use the stanchions for mounting. They are vertical and already in place. I have done this in the past and it works well.
Delta-T likes this.
Brian
mitiempo is online now
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
