Low buck projects- Let's see 'em! - Page 93 - SailNet Community
 1223Likes
post #921 of 1560 Old 12-13-2013
Senior Moment Member
SloopJonB's Avatar
Re: Low buck projects- Let's see 'em!
I bent a set of stanchions doing that.
SloopJonB is offline
post #922 of 1560 Old 12-13-2013
mitiempo's Avatar
When I did it I didn't have to bend the pvc tubing that much. There was very little bending force on my stanchions. Survived two winters without a problem. Also the tarp is not stressed this way, not like a tarp that is stretched by itself over the boom.
Brian
mitiempo is offline
post #923 of 1560 Old 12-13-2013
Delta-T's Avatar
This PVC frame I did build for sailing purpose, but not for covering the boat. I just adapted it for covering a boat for you all. I really don't advocate covering boats, but if you have to cover, it should be an easy good design, so I though I would share. I can not find the pictures of when I had it set up, 60' long, in my back yard, to recondition my mast. Winter project. I now use some of the frames to hole netting up over the coy pond.
To attach the frame I would lash to the outside of the stanchion base only, or if you have a toe rail that has holes in it, and on the outside of life line. Stanchions and life line will be inside the cover and should clear the life line and not touch them. Tarp should be tight enough so no snow or water can not accumulate on top. And when you attach the beam rope tighten it down to squat the frame bending the frame to bow it around. This will give it spring and hold it tight and will not allow for much side to side movement. If you make the top two PVC pipe longer to make the frame wide enough to clear the life line and stanchions, then bend them in (this will work fine too), you will need to add gusset ropes inside from the side 45 deg elbows across to the base of the frame to keep cover from swaying. Tying off to the mast will eliminate most swaying and or planing to use the boom just under the frame will work too.
If you would like me to show these options in plan form, I will be happy to do so.
Think spring!
Eric
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #924 of 1560 Old 12-13-2013
I made a similiar frame from pvc years ago and its still going strong. If it will help, several points that have worked well on my frame...I drilled 2 holes in pvc center ridge about every three feet
for 3/4" ribs which pass though center ridge and connected 2 pieces of the 3/4"
rib material as needed then cut to desired size , they fit into holes in pvc that run along
(inside) port and starboard toe rails.(ribs and all numbered) This creates tension that works well and can be carried all the way back to the stern. Another big help is using plastic ties to hold things in place when setting up and from wind, come spring they cut off real easy.
Pretty strong, stands up to wind and snow.
Hope this helps.... Hugo
Thumbnails
Above post was from prev. thread.... but the pictures just wouldn't travel with copied text. If any interest in pictures they are on thread titled...
"I just don't get it. Winter storage " 2/16/2011 post # 31....frame is really a thing of beauty.
Sorry but when it comes to sailnet and pictures "I just don't get it!"
Delta-T likes this.
HUGOSALT is offline
post #925 of 1560 Old 12-13-2013
Thanks Eric and others for the input on mounting the frame to hull-Chris
White Knight is offline
post #926 of 1560 Old 12-14-2013
Thumbnails
I copied the entire post from the other thread because there are some really good ideas here! And, it took me a while to find the damned thread for some reason. linky
Thanks Hugo! BTW, you can get the images by hitting the quote button on the post, then copying the code.
trkarl is offline
The Following 2 Users Say Thank You to trkarl For This Useful Post:
bljones (12-17-2013), SloopJonB (12-14-2013)
post #927 of 1560 Old 12-14-2013
Delta-T's Avatar
The problem with any flat top, is snow is going to accumulate. There is no need for structural ridge beam. If you think that will hold snow or any cover can, good luck with that.
And keep in mind this is a low buck project...under $100. 5 or 6 frames of my design (for a 32' boat) and about $10 each frame and 3 3/8"x100' rope from Walmart for $5 each. Project is frame only, no tarp cost. Project is not how to cover, but how to build a cheap frame that will hold up.
Eric
Delta-T
Delta-T is offline
post #928 of 1560 Old 12-15-2013
Looking at these frame designs I cannot see how/if the tarp is attached to the frame at any point.Can someone enlighten me on this subject please.In New Zealand we do not have a snow problem per sec,my interest lies in building a frame to cover a boat when out of the water for major refurbish.-Thanks-Chris
post #929 of 1560 Old 12-15-2013
mitiempo's Avatar
Question Re: Low buck projects- Let's see 'em!
When I did this the tarp wasn't attached to the frame. It was attached to the toerail with cord and/or bungees, just using the frame for support. That is the advantage of this as there is less strain on the tarp. When the tarp is just over the boom as many do it has to be tight and wears out a lot faster.
Brian
mitiempo is offline
post #930 of 1560 Old 12-15-2013
Originally Posted by mitiempo View Post
...When the tarp is just over the boom as many do it has to be tight and wears out a lot faster.
.. and when the sail and cover are left on, just as hard on the sailcover too!
Faster is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
