Low buck projects- Let's see 'em! - Page 94 - SailNet Community
 1223Likes
post #931 of 1560 Old 12-16-2013
Re: Low buck projects- Let's see 'em!
Thanks again guys-all clear now-good tip on the wear factor too-Chris
White Knight is offline
post #932 of 1560 Old 12-27-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Refinished tiller.
The only thing I had to buy for this project was some low density filler to add to some epoxy. So I spent around $14 just for this project. Sandpaper, varnish, mineral spirits, scraper, were already on hand.
The handle end of my tiller had split apart and varnish had failed so it was not looking very good. I had to remove a couple small dowel rods by the handle, scrape off the old varnish, filled the split with epoxy, then sanded with 80 grit, to 100 and 220. Between coats of varnish, I used 220 to rough it up for the next coat. The varnish I used is Epifanes Gloss Clear that I have used previously on a couple handrails.
Here's some pictures of this project.
Larger pictures can be found on the write up I did for my blog: Rhapsody: Tiller Time
I really like how it came out. I'm looking forward to how it will look back on the boat this next season.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #933 of 1560 Old 12-27-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Originally Posted by Rhapsody-NS27 View Post
Refinished tiller.
NICE JOB!!! LOOKS GREAT.
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #934 of 1560 Old 01-01-2014
Randy Hines
randyrhines's Avatar
Originally Posted by AllThumbs View Post
Nice table bljones. It looks like it belongs.
I still can't remember if you owe me money , but I like the table, my compliments captain.........
randyrhines is offline
post #935 of 1560 Old 01-01-2014
Randy Hines
But I'm pretty sure it you that took the last beer......
bljones likes this.
post #936 of 1560 Old 01-05-2014
ericb760's Avatar
This is my newest "on the cheap" project. I bought a case (10 piece) of outdoor eucalyptus tiles. I had to trim the last two to fit around the base of the tiller. This was the dry fit and they work perfectly. Now I have to trim the tabs off the sides. I paid $50.00 on Amazon. I don't expect that these will last for years and years, but, it beats $500 for a custom made teak sole...
ericb760 is offline
post #937 of 1560 Old 01-07-2014
ericb760's Avatar
Here's my second Low Buck project that I completed recently. When I bought the boat it had smoked plexiglass drop boards that really didn't fit the design of a classic boat. So, I purchased some furniture grade plywood and cut them using the old boards as a template. After sanding, staining, and four coats of marine varinish, at a cost of around $30, I had new drop boards!
ericb760 is offline
post #938 of 1560 Old 01-07-2014
No more curry buffets
Ritchard's Avatar
Originally Posted by ericb760 View Post
Attachment 17570
Attachment 17578
Oddly, I did the inverse of that, I made a plexi drop board to allow more light into my old boat. Man, is Plexiglass ever expensive. Yours look great. A word of advice, pay careful attention to the edges of the plywood. If the finish gets worn enough to allow moisture in, your plywood will delaminate. You may want to put a fresh coat on the edges each year. For more protection, you could remove the varnish on the edge and do a coat of epoxy, then cover with varnish. It will then be much more impervious.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #939 of 1560 Old 01-07-2014
ericb760's Avatar
I'll definitely keep that in mind. Of course, I could have bought marine grade plywood with a teak veneer, but then that would not have qualified as "Low Bucks"!
ericb760 is offline
post #940 of 1560 Old 01-07-2014
Senior Moment Member
SloopJonB's Avatar
The best treatment for "outdoor" edges on ply is to trim them back a smidge and edge them with solid hardwood.
Makes a much better "running" surface for them to slide on as well.
Ritchard likes this.
SloopJonB is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
wsmac
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
