12-29-2008
How is the water level in the batteries?? If you haven't checked it recently, you probably should.
If the water level is low, the batteries could be low due to the electrolyte levels not covering the plates fully... in which case, the batteries are likely toast.
I just added a 25 watt solar panel to the boat to keep the batteries topped off on my boat today.  It goes through a charge controller and should be able to keep up with the parasitic loads as well as the self-discharge rate of the wet cells.
