Old 12-29-2008
thisisus is on a distinguished road
Sizing Winches
Our Islander 32 currently has 2 speed Lewmar 40's for the primary winches. How do you determine if we should go to the next size up or stick with what we have when we upgrade the self tailers. On the high speed side does not take long before it's useless and have to go to the low speed side to bring in the genny. Will going up one size help or will we just spend some more money for nothing. thanks
Thisisus
Islander 32
Old 12-29-2008
catamount's Avatar
catamount is on a distinguished road
You would want to go up in size if you find that you have to work too hard to crank in the last bit of sheet. Bigger winches with higher power ratios want necessarily make it longer before you have to change down to low speed, but they will make it easier to crank the winch.
You might take a look at Harken's "CompuSpec" -- an online tool that will calculate the loads you might expect to see and then help you figure out what hardware to get to match.
Harken Compu Spec
They recommend 2-speed size 40 winches for the genoa sheets on an Islander 32-1
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
Old 12-30-2008
You probably don't need larger winches for your genny. Hopefully, the Lewmar 40STs will have the same bolt pattern as the existing Lewmar 40s do. That'd simplify the installation a good deal.
Old 12-30-2008
jason3317 is on a distinguished road
Most experts feel that the avg person can exert 35 lbs of pressure on the winch handle. If you multiple your genoa size in sqft by 6, and divide by 35, that should approximate the winch power ratio. On my 260 sqft genoa, that results in a size 44 winch. Most production boats equip at 45 lbs of pressure...making their standard winches "undersized"...at least theoretically.
Old 12-30-2008
On low speed they're still pretty easy to get in....high speed you hit the wall pretty quick. Course self tailers will go along way I think. I'll have to do some calcs on the genny size and see what that number is. Would be nice to use the same bolt patterns, but what fun would that be if something was easy to fix or install on the boat. Takes all the challenges out. Thanks for the hints and advice
ISO advice re sizing winches brainstormers Gear & Maintenance 0 07-09-2004 07:03 AM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
